I am a bit confused about coil windings in two 12V machines DanF built before.
I am looking to start similar project, but there is much confusion in different pages about 10' machines. Can't collect all the data, every machine is so different. But I'll handle that, I guess, because I start to write down all the data available from different pages, so I'll probably cath it at the end. Just need some time. What confused me most was about the coil windings. Here are two examples, both for 12V 10' generators, with different coils.
Page1: www.otherpower.com/davesmill.html
His system is 12 volts, so were building the machine for that., ...
and: The coils are made up of 65 windings of AWG 14 wire... and
But it seems to be hitting cut in voltage (12 Volts) perhaps a bit below 100 rpm
At the other page:
http://www.otherpower.com/timsturbine.html
It says:
This is a 12 Volt machine, and each coil is wound up with 34 windings of 2 strands of AWG 14 wire.
The alternator came out pretty nicely with a cutin speed of exactly 150 rpm (it's producing 12.5VDC on the DC side of the rectifiers at 150 rpm)
I know Tim's turbine is the last evolution of the 10' turbines. Is it the right way to go? I got 2x1x0.5" magnets, and Dave's machine is built with different ones.
Should I use the plans for Tim's stator? I think so, but need advice.
