No afcs not knowing the answer is not stupid,
You would have to fabricate the rotors from plate steel and solid steel for the boss. eg. If the rotor was made from 12inch round plate steel, 5/16"thick. You would then weld a 2inch piece of solid round steel 3/8 inch thick front and back. Then you would turn out the hole in the center to the shaft diam and machine keyways into both the shaft and the rotor. The rotor would now have a thickness at the inner hole area of 3/8 + 5/16 + 3/8 inches. from the 2"radius out to the perimeter, the rotor would be 5/16 inch. With two of these rotors on the shaft, pressed up against each other, they would have a gap between them of 3/4 inch for the stator to fit into. If the stator is thicker then spacers between the boss's would increase air gap, if you needed smaller, then you would machine the boss down to less than the 3/4 inch.
Like I said, a lathe would be necessary, but the project would be possible.
Without machine tools, perhaps better to use the piggot design ..tried and true.
The design you are talking about is nice, but is the kind of thing you would build because "you can ", not because it is better than the usual design.
It must be remembered that the reason most people build the piggot design, is that is has proved to be very doable for the average person, and very successful. If you wish to go against popular practice then that is perfectly fine, but it is the path that should only be trodden by those prepared for a failure or two. If you need instant success, then do it the way most people do. They do it that way for a reason.
I'm happy to do things differently, but I have a pretty fair workshop, and couldn't care less if I fail, I can just keep modifying till it works...coz I can.. Sometimes thats more important than the best..... ask any vawt practitioner, they are clearly behind the eight ball, but they are prepared to keep trying new things...oneday they will get one to work very well, instead of barely adequately, but the fun is in trying.
If you need power not amusement, I would urge you to build the normal design. If you crave amusement, and power is a bonus, then feel free to experiment. I choose the second path myself, but everyone has different needs.
........oztules
