I'm finally making preparations for the first real windgenny (but the 3rd axial flux generator). I'd like to know whether my figures are more or less ok for the alternator itself. It's going to be a 10footer, but initially will probably only run with an 8ft prop (for about a year or so, for testing), by opening air-gap.
prop 10ft (8ft initially)
abt. 200W power
- V system voltage (externally rewireable for star or delta)
- /12 dual rotor axial flux
magnets N40 50*25*12.5 (2"x1"x.5")
coils:
- turns each
- coils/phase
wiresize 1.6 mm (AWG14) (but perhaps 1.5mm, not sure yet)
coil thickness 8mm (5/16"), a bit thinner than the usual 10mm (3/8")
I think I'm getting pretty close to the correct values, but I'd like to know what youse think. The alternator is supposed to be a fairly standard 10foot generator, but as said, will also have to be able to run with an 8ft. prop for a while (perhaps forever?). The alternator however should be built to handle the 10ft prop and power.
Peter.
