It's 1175. That would make it a 6 pole stator, right? Which would mean there should be 6 sepearate coils, correct?
Yes, it is a 6 pole, but no it does not have 6 separate coils. You will have far more than 6 coils.
I didn't...I made the 10 footer for something else and thought I could use it here. What's a good way to determine proper size?
Decide how much power you want. Then, look at the power in the wind to determine prop diameter. Then, build a genny that can harvest that windpower.
Or, build a genny to produce a certain amount of power, and then look at the available power in the wind to determine what size prop you need to maximize the potential of the genny.
And how could I run this motor without magnets? If I understand it correctly the only way to run it without magnets would be to run it at slightly higher RPM than rated + use running capacitors. There's no way I could get it to spin nearly 1200rpm. If I'm missing something I'd love to know what it is (<- that's an actual request, not smartass remark).
I believe you can overspin a motor by 10 or 15% of rated speed to produce power. It's not as efficient as using magnets, but it will work.
You can also gear up the genny from the blade rpm. Again, massive inefficiencies, but it will work.
Will the rectifier automatically bring the A/C input to battery charging voltage? I'm still learning how they determine output with them and how it's effected with the fluctuations of wind input.
The rectifier ONLY changes AC current to DC. The batteries will hold the voltage down. Once the genny reaches cut-in voltage, the batteries hold the voltage there. After that, the power fluctuations are amperage changes.
So then using smaller magnets would be better if I understand correctly...they're cheaper and you can easily fit a larger valume in the same space. Probably only better way would be machining groves into the rotor and solid magnets.
You understand incorrectly. 'Small' magnets has NOTHING to do with volume. Volume is volume. Whether you calculate the sum total volume of many small magnets, or the sum total of fewer larger magnets, volume is still volume.
How many magnet banks sould I fit on the rotor? Zubbly's setup has 3 rows of 15...should I stick with the three rows if I've got 6 poles? I'm not sure how to figure that.
IIRC, the 3 rows of magnets on Zubbly's conversion were 1 pole, of the several total poles on his rotor.
You will need to decide how thick of magnets you will be using. Then, calculate what your rotor diameter will be that you add magnets to. Divide into 6 equal sections so you can put 6 poles on the rotor. Calculate the skew. Measure how much space you have left in the section, and see how many magnets will fit in that space.
