Author Topic: Advice needed please  (Read 1015 times)
validoe
« on: November 07, 2006, 06:29:55 PM »
 Hi everyone!
First of all, I hope you will understand my english and I apologise in advance if you not...
  I have been reading posts on this forum for months and in the same time i have started to build a wind generator using your experience and ideas.
  at this moment i have finished the metal work and the blades and before glueing the magnets and winding the coils some advice will be verry apreciated.
  my project is an axial flux generator (hope I got this right :) dual rotor and the steel disks are 250mm (10") diameter, 8mm thick (i understood here that the thicker, the better, less flux leack).
  The propeler is 2,7m (9') diameter-3 blades.
  Unlike most of you people use 2"x1"x.5" magnet blocks, all I could get is 40x20x10 mm,but at least i have plenty of them. this is the reason i went for 10" not 12" diameter steel rotors.
  I was hoping to compensate the size of my neos by increasing the number of poles and go for 16 poles instead of 12 but when I tested the allignment of my magnets on the disc i realised they are too close to each other at the bottom side and i'm not sure if this will affect the performance.
  Now the question(s):
Should i go for 16 poles/12coils or stick to 12/9coils?
Can you recomend the size of coils( number of turns and wire thicknes)?
I'm aiming for a 12V machine
  The machine will be mounted on the top of a 40 meters tall building with fair wind most of the time.
Tha!nk you , any help will be much appreciated!
PS Iwill post some pics as soon as I learn how to resize them.... :)
« Last Edit: November 07, 2006, 06:29:55 PM by (unknown) »
Re: Advice needed please
« Reply #1 on: November 07, 2006, 12:42:50 PM »
I think you will need to use 16 poles with 12 coils.
You should do a test coil, but I think you can manage with 30 turns per coil, with care you should get 13AWG in and you should be able to do it with the stator 1/2" thick.
It should work out ok for the 9ft prop.
« Last Edit: November 07, 2006, 12:42:50 PM by Flux »
validoe
« Reply #2 on: November 07, 2006, 01:08:26 PM »
 Thank you for the quick reply, just one thing still not clear. i'm not familiar with US units so if you can convert AWG in metric please or point me to a site where i can do it i will start work tonight :)
 I beleive AWG reffers to wire thickness, right?
« Last Edit: November 07, 2006, 01:08:26 PM by validoe »
tjspears
« Reply #3 on: November 07, 2006, 01:14:40 PM »
« Last Edit: November 07, 2006, 01:14:40 PM by tjspears »
« Reply #4 on: November 07, 2006, 01:37:36 PM »
1.8mm diameter is about the nearest number.
flux
« Last Edit: November 07, 2006, 01:37:36 PM by Flux »
validoe
« Reply #5 on: November 07, 2006, 11:05:35 PM »
 Thank you very much for the info, i will make 1 coil only and test it. I think i can fit 12 coils on the disk . Hope to post some results soon
  Thankx again!
« Last Edit: November 07, 2006, 11:05:35 PM by validoe »
