Often Epoxy is said to be allot more expensive, But is it really? A little maybe, but enough to worry about? Not if it makes a better product I think. I'm comparing Epoxy to Vinyl Ester by price and volume here. Not cheap $20 fiberglass resin.
I am not sure it's all that expensive unless I was looking at something else. You get more Epoxy Volume so it SEEMS to be allot more costly buying a gallon, but it's not much if you break it down.
The cost of Vinyl Ester was $38.50 for a gallon, it has a tiny tube of hardener. You get 1 gallon total volume.
The epoxy's I looked at cost more yes, but reading the fine print you actaully get MORE.
1 gallon of Epoxy uses more than 1 quart of hardener, it says to add the amounts together to figure the volume when mixing. Therefore you get over 5 quarts in volume, and when I divided that price by 5 and multply by 4 it gets really close to the cost of Vinyl Easter. Only $4 a gallon more!
"Epoxy with 3:1 Ratio Medium Epoxy Hardener, Resin Amount 1 Gallon, Hardener Amount 42.6oz, price $53.00"
That's a volume over 5 quarts, so less than $10.60 quart.
Vinyl Ester cost me $38.50 for 4 quarts total volmue, $9.63 a quart.
The epoxy is only $1 a quart more, or $4 a gallon more.
If your going to use that much resins/epoxies it makes a difference, if you only need 1/2 gallon total none of the above matters cause you won't use it, then the Epoxy costs allot more because you don't need the extra volume anyway.
So for $4 difference the real question is which is better? Epoxy for everything? Epoxy for just rotors? Etc... Or is Vinyl Ester better?
I don't care about the $4, I want the best product for the job.
Is Vinyl Ester or Epoxy best for stators then? I bought Vinyl Ester for mine, but wondering!
