Author Topic: Few more Q's on the 20 footer...rotor diameter  (Read 744 times)
ve7khz
« on: March 02, 2007, 06:10:34 PM »
Hi Dan,
Reviewing your 20' article you stated you wanted to get 45 turns of #14 on the coils but could only get 45 turns of #15. How close was it to not fitting? .10" or .25" etc.?  If I were to make the rotor 24" and the stator 30", do you think that extra 1" in radius would allow enough room to get the 45 turns of #14? I'm shooting for 5KW at 40KPH with 20' blades on this alternator.
I have my machine shop all ready to go with the plasma cutter but don't want to commit until I make sure I'm only going to do this once.  :-)
Thanks again for your help.
Paul
« Last Edit: March 02, 2007, 06:10:34 PM by (unknown) »
ve7khz
Re: Few more Q's on the 20 footer...rotor diameter
« Reply #1 on: March 02, 2007, 11:51:40 AM »
Well, it took a little searching for arc length formulas and it really hurt my brain but I figured out that going up 2" in diameter on both the rotor and stator will give me an extra .21" between the coils. I hope that will be enough to let me use #14 wire.
Hope that makes it easier to answer my question.
Paul
« Last Edit: March 02, 2007, 11:51:40 AM by ve7khz »
wdyasq
« Reply #2 on: March 02, 2007, 02:28:10 PM »
Paul,
A couple of things. This entry is better suited for a diary. In fact, a diary is a lot easier on finding stuffs. This goes for all of us.
In doing some research on winding 'string' I found the density one can wind wire is ~60% of solid. For example (truely made up numbers here), If I had a square inch of winding area and my wire had a cross section of .01", I could get 60 turns (and maybe a bit of puffin or seagull) in.
« Last Edit: March 02, 2007, 02:28:10 PM by wdyasq »
