Hi MattM!
Basically the drawings Brian created are just about exactly the blades the Scotty makes for us, and Scotty showed Brian (Boss) Kevin and Jessica how to carve them - then they made drawings. I carve them slightly differently but this is very close. It is a compromise between... easy to make - good performance - inexpensive materials (designed to be build from a 2x8)
'The blades would probably not perform quite as well as you would hope.'
I think they perform very well and they're very quiet.
' You have a very limited pitch to the blades which is fine if the wind is blowing extremely hard and you want uber-speed.'
Not really - they start in very low winds and run at TSR between about 8 (at startup) and 5 (at furl) - this depends on the alternator and the load.
' Unfortunately you trade a lot of your mechanical advantage of the blade at low wind speeds for that high wind speed performance. '
No - we dont actually ;-)
'This is why the typical blade has twist, to take advantage of both ranges of wind speed.'
No - that is not why typical wind turbine blades have twist... the twist is to take best advantage of any wind speed. Even if windspeed was always exactly the same - say 10mph with no variation 24/7 you would still want twist. These blades actually do have twist, and when I carve them I'd do things slightly (only slightly) differently. In practice though it makes little difference. Lots of wind turbine blades make the compromise of having no twist to ease manufacture and the loss in power is small.
'I know that the typical blade is nearly zero pitch at the extreme and has most of the pitch at the inside of the blade.'
Yes - actually lots of blades (ones that run really fast) have negative pitch!
'But if one looks at it from a mechanical perspective you'd think the pitch would be best at the extremes and the least pitch at the interior.'
I think you misunderstand how wind turbine blades work.
' The wind turbine is on the opposite spectrum from a powered propeller, therefore the design should be different. In that way the wind would be using the blade as a long lever and need much less pressure to startup rotation and the thickest area of the wing would be prime real estate for the most extreme wind speeds. '
Again - I think you have 'drag machines' stuck in your head. These are more like 'airplane wings' than 'airplane propellers) I wont get into how wind turbine blades work and why here - there is a lot of good reading on that but you definitely have some misconceptions I think.
There is good stuff on Hugh Piggotts website: scoraigwind.com
This is a cool site too: http://www.windpower.org/en/tour/wtrb/blades.htm
And there are lots of others...
