Author Topic: new motor  (Read 3892 times)
97fishmt
new motor
« on: April 04, 2008, 11:16:04 PM »
Well its time to get started again on another unit.
I really am addicted to going further and further.
I watch the brushless servo motors on ebay and sure
enough one came to my door today. WOW brand new in
the box what a score. Will make a nice 600 watt machine.
I have a collection of rotors but time to start carving.
This one I think will need a little less speed and more
torque, so maybe 10' and more drop. My welding skills are
getting better and I feel better about going for the tilting
tower base myself.  I did not trust my skills so much before
and did not know where to turn to get it done.
Thanks to all that share here and for a place I feel
right at home.  You folks are like part of my family. Thanks!
« Last Edit: April 04, 2008, 11:16:04 PM by (unknown) »
97fishmt
Re: new motor
« Reply #1 on: April 04, 2008, 09:08:24 PM »
Here is a picture
« Last Edit: April 04, 2008, 09:08:24 PM by 97fishmt »
jzeveney
Re: new motor
« Reply #2 on: April 05, 2008, 07:16:10 AM »
That's a big DC motor I think what are your plans for it?
Z
« Last Edit: April 05, 2008, 07:16:10 AM by jzeveney »
Old F
Re: new motor
« Reply #3 on: April 05, 2008, 08:13:45 AM »
Nice looking motor what is its rated RPM ?
When people ask  me if I know what I am doing
I just look them in the eye an say heck no hasn't stopped  me in the past an wont stop me in the foreseeable future  :  )
Old F
« Last Edit: April 05, 2008, 08:13:45 AM by Old F »
97fishmt
Re: new motor
« Reply #4 on: April 05, 2008, 10:07:36 AM »
Hey F and Z
This is another Ac servo motor.
Nice ebay find $35.00.
  1. pounds of copper and magnets.
  2. 2 Ohms resistance in the windings,
  3. vrpm, 33amps. It will work well for
my 12volt system.  This is about half
the size of the one I use now! I just
can't resist when they go for so cheep.
One of these days I'll just have to say
O.K. to the nice 18kw ones close to 400
pounds. This is the pma I use now 9kw motor.
« Last Edit: April 05, 2008, 10:07:36 AM by 97fishmt »
97fishmt
Re: new motor
« Reply #5 on: April 05, 2008, 10:31:55 AM »
Whoops!  That should be 80v/krpm.
So 12.5v @100rpm. (1000/80=12.5)
O.K. so 12.5*1.4=17.5
17.5volts @ 140 rpm. Diodes
and line loss  should get me close
to good charging voltage at the batteries.
You can see this is low for cut in. Thats
why I think a big slow machine is here for
the making.  I do the furling just like the other
machines here, I just don't have to build the
alternator, and its totally sealed.
« Last Edit: April 05, 2008, 10:31:55 AM by 97fishmt »
97fishmt
Re: new motor
« Reply #6 on: April 05, 2008, 11:13:51 AM »
Now that I think about it, This will probably
make a better unit for a 24volt system.
12.5*2.6=32.5 so: 32.5 volts @260 rpm seems
more normal. Oh well that will make it 1200 watts
or more.  I play with transformers and higher voltage
machines as well. I just want to find the nice slow
and tame with my winds. Like I said I am addicted!!
« Last Edit: April 05, 2008, 11:13:51 AM by 97fishmt »
coldspot
Re: new motor
« Reply #7 on: April 05, 2008, 08:48:41 PM »
97fishmt-
 Cool, very nice E-bay score!!
 "70lbs of copper and magnets."
 AC servo motor
Very close to my
 "28lb stepper motor", 28 pounds of copper and magnets. Cost $0.99 plus $22. shipping ! LOL  :)
 Makes way more than I can handle yet so I'm flying it blade less on a normal pipe over pipe with side furling as normal. (Waiting for better tower and over voltage controls)
 I've done a little testing with E-bay 86.5" fiberglass blades and improved ceiling fan blades at about 4'. MORE tower needed!!!!
« Last Edit: April 05, 2008, 08:48:41 PM by coldspot »
$0.02
CmeBREW
Re: new motor
« Reply #8 on: April 05, 2008, 09:11:32 PM »
Very nice looking and tough motor .  I wish I understood about those type motors!!!
I have NO idea how a Brushless AC(??) Servo motor works??. (or the volts to rpm rating would be)
Are there Actually big ceramic magnets inside the motor for the field??
I don't fully understand the rating numbers that you gave. (volts/rpm)
Do you happen to have a photo of the ratings label on the motor up close?
Sure sounds like those type motors 'kick the booty' of normal PM DC motors as mills.  Before seeing your post, I USE to be very happy to see 7 amps in big wind from mine. Now, I sorta feel alittle ashamed, confused, and disgusted!
« Last Edit: April 05, 2008, 09:11:32 PM by CmeBREW »
97fishmt
Re: new motor
« Reply #9 on: April 05, 2008, 09:12:51 PM »
Hey,
How did those blades work?
Have you tried to carve any out of wood yet?
It is like they say, you can get away with a lot.
I made some out of some bed slats once, and man
I still use them on my 99v amatek motor and get
a good 30 amps out of them with no twist at all.
Just airfoils on the back and about 5 degrease of
angle into the wind. Cool, Thanks for saying Hi.
« Last Edit: April 05, 2008, 09:12:51 PM by 97fishmt »
97fishmt
Re: new motor
« Reply #10 on: April 05, 2008, 09:23:40 PM »
Hi, look at some of the other things I
have posted. I took one apart one time
and showed the neo magnets and the name
plate.That one just had a coating on the
windings so you could not see wire gage.
These motors are just 3phase alternators
just like they build here on the board.
All you have to do is add diodes to charge
a battery.  Look for more amps if you are
looking for good power.
« Last Edit: April 05, 2008, 09:23:40 PM by 97fishmt »
97fishmt
Re: new motor
« Reply #11 on: April 05, 2008, 11:17:08 PM »
I should be a little more specific.
It does depend on the winding of the motor you
are looking at. If you want to use it to generate
power, the voltage and ohms and amps are what you
want to look at, and what you want to get out of it.
I am not qualified to give advice, but if you can
experiment fairly cheaply then why not try to find
the holly grail, eh!
« Last Edit: April 05, 2008, 11:17:08 PM by 97fishmt »
coldspot
Re: new motor
« Reply #12 on: April 06, 2008, 03:08:31 PM »
97fishmt-
 Hi, again,,..  :)
"How did those blades work?"
which ones?
 The ceiling fan ones failed again, the mounting arms that is.
 The F/G ones are great, maybe a bit more that the stepper can handle. The ceiling fan ones could still
just barley turn it shorted out in winds over 13 mph. I'm planning on using them on a 2HP conversion.
Also testing an 102" set on it also, if I ever get it into action.
 "tried to carve"
Well, I've started a small set,(6') but just can't get myself to go any farther, being that I have two 86.5" sets and the 102" set.
 I lack a real tower still but, I'm getting closer.
How long are your ones on the Ametek? Also how many?
« Last Edit: April 06, 2008, 03:08:31 PM by coldspot »
$0.02
97fishmt
Re: new motor
« Reply #13 on: April 06, 2008, 06:01:35 PM »
Yes I just did not wont to write out fiber glass
They work good huh?  The small windmill is a 99v
with 6' blades here.  Thats all I can get on this
little test tower.  It is on like a cliff or drop-off.
Good wind if it comes from the right direction.
With a belt sander I made these blades in about 2 hours. Hub and
mounted on the stand in about 3.
« Last Edit: April 06, 2008, 06:01:35 PM by 97fishmt »
CmeBREW
Re: new motor
« Reply #14 on: April 06, 2008, 06:18:14 PM »
Thanks 97fishmt,
     That will give me something more to study on over the months.  Sounds like a lot of fun and payoff. I wonder if a 10' diameter set of 3 blades has any problem in low wind getting over the strong cogging of such a strong neo stator motor??  Inotherwords, is the cogging bad?
« Last Edit: April 06, 2008, 06:18:14 PM by CmeBREW »
97fishmt
Re: new motor
« Reply #15 on: April 06, 2008, 07:09:47 PM »
Hi, there is now cogging with these motors.
They turn just like a car alternator.
They have the magnets skewed on the armature
and the 3 phase winding in the case.
I hope just to pass it on. I see so many
people trying the tape drive and treadmill
motors, when they could go into the real thing
for about what they are spending, and wont be
disappointed like they will be with a brush motor.
« Last Edit: April 06, 2008, 07:09:47 PM by 97fishmt »
CmeBREW
Re: new motor
« Reply #16 on: April 06, 2008, 08:19:54 PM »
I never knew that. That is surprising and Very good.   Thanks for sharing the experience and info.
« Last Edit: April 06, 2008, 08:19:54 PM by CmeBREW »
97fishmt
Re: new motor
« Reply #17 on: April 06, 2008, 09:07:06 PM »
I meant No cogging.
« Last Edit: April 06, 2008, 09:07:06 PM by 97fishmt »
97fishmt
Re: new motor
« Reply #18 on: April 07, 2008, 04:16:03 AM »
Wow!!  What was that all about??
I thought you guys would bust me on that math.
I don't know why I was trying to divide 1000 by 80
to get 12.5  That is something totally different.
To excited I guess and I should not go to all this
trouble to confuse everyone else.
Back to the 80 volts for 1000rpm. That means 8 volts for
100rpm.  So 16 volts for 200rpm. Damn! I new I was loosing
my mind, I guess I'm just not sure of it yet.
« Last Edit: April 07, 2008, 04:16:03 AM by 97fishmt »
coldspot
Re: new motor
« Reply #19 on: April 09, 2008, 10:16:54 AM »
 97fishmt-
 And everybody else
 "They have the magnets skewed on the armature
and the 3 phase winding in the case."
 Thats what I've been trying to say about my
"CMI",(Controlled Motion Inc.) Stepper Motor !!!
 But when I posted about it and showed pictures of the inside,
("http://www.fieldlines.com/story/2006/2/25/17110/5246") somebody posted back that those can't be magnets or they would be stuck to the tape I used in the picture. Hey, I was the one holding the tape and camera. I know how hard I had to pull on the tape to get it to NOT get pulled to the magnets.
 When you turn its shaft you do feel the steps but it is very soft and less than a few oz's of pressure to get past the steps.
 I don't know if its any better than a Ametek or not but I do know that it has no brushes to replace and was right in the price I paid for my 30 VDC Ametek, ($20. Vs $25.)
 Someday I'll be able to post some real info with all the V's & A's so watts will be able to be seen.
 Someday, with a real tower and blades, I hope this year!!!!
$0.02
OK,OK I know that was only a very lucky buy but, don't count out these types of things,
Steppers and servos
thats all
« Last Edit: April 09, 2008, 10:16:54 AM by coldspot »
$0.02
97fishmt
Re: new motor
« Reply #20 on: April 09, 2008, 07:29:04 PM »
Hi coldspot,
I have seen that type of motor in researching pm motors.
Its a cylindrical magnet. I've never seen one or not quite
sure if I remember how the north and south poles are set up
on them.  For stepper motors I thought they had the windings
on the armature and the magnets in the can like a f/p motor.
I'm glad to hear from someone a with similar interests.
« Last Edit: April 09, 2008, 07:29:04 PM by 97fishmt »
