Well..Looks like I had better do my own measurements then.
And the hub diameter of the Futurenergy blade set is smaller than the OD of the Smartdrive. This will be a problem.
A bit of info:
FE use the blade set made by Multi-wing (europe, +Autralian Distributor)
Multiwing informed me that Futurenergy are not supplying UV rated blades.
UV rated blades are grey in color. FE use the black blades that are not UV protected!
Also, quotes from Multiwing Australia for 6,8 & 10 position hubs and additional blades were outragous. Too high to consider, even before the "crash"
Now I read an old Back-shed post re Seely AirConditioner PM motors. I assume they fit them to the Inverter type AC's. Hmm.. I might contact an importer of generic chinese AC's and try to salvage a motor from an "inverter type" AC..if suitable.
I've got a good set of blades but no Alternator to spin.
Cheers All!
