I am in the process of assembling my 10' generator. I have a couple questions I would like to run by the group.
1. I bought the magnets with the holes. If I press a 3mm roll pin into the steel rotor and put a coat of epoxy on the bottom, do you think this will be sufficient to hold the magnets in place?
2. I want to do some bench testing to check performance and establish a baeline at different rpm's. What is a good way to measure RPM's?
3. Any suggestions on a bench test rig? I figure I can put a hand crank, or turn with a drill, but this would be for short runs. Is there any advantage to running this at say 500 Watts for a period of time for heat dissipation testing?
I am interested in doing this testing as I really don't have a tower to put this on yet. Spent all my extra science experiment money on building the generator. I did get an offer for some sections of 2" pipe, hopefully enough to erect a 15-20' test tower. I am looking at building a 40' tower out of 3" sched 40 pipe soon.
The ground has thawed up here in Michigan and we have a couple months of the mud season to deal with before we can think about erecting towers.
Will be assembling soon, pictures to come in my diary.
