Well, sort of. Many of us would consider a 50 watt windmill a garden ornament, a fun weekend project, and cheap to build, be it VAWT or HAWT. But to others, a 50 watt garden ornament will do just fine. If their only usable location is their back yard, and they have turbulent winds, then a VAWT will work just fine.
Its when they try to scale up that the problems in VAWT's start to show up. If you want more power, you need clean wind and a HAWT. A VAWT can be scaled up too, but it will cost you heaps, the engineering is a nitemare and its just not good sense. I have had a mix of VAWT's and HAWT's, the VAWT's are fun and at times work better than the small HAWT's, but I would never build a big VAWT again.
It depends on what you want from your windmills. If its a hobby, and the fun is in building the windmill as well as watching it spin and make power, and you dont expect much power, then a VAWT can be just as rewarding as a HAWT. But if you want to build a serious windmill, a HAWT is the sensible way to go.
Glenn
