Hi Shadow ~ good discussion here for sure.
'I'm always happy to see someone working on a brake system for these type wind turbines!'
Me too, there can surely be no harm in it and I tend to agree that for larger machines especially, it's probably wise.
'I know the Dans dont think they are required or necessary but man oh man every second day on this forum is another story of another run away wind turbine.'
It does seem a common topic these days. Although in most cases it seems to me that folks are deviating quite a bit from past designs. Which- is good and only leads towards progress in my mind, but I should hate for folks to get the idea that the furling system is unreliable. In my mind, it is one of the most reliable governors for a wind turbine ever. And deviations include those in the alternator, those in the basic frame/geometry of the wind tubine itself - and loads. Using a single resistor as a load with no regulator is pretty risky. Having a very long/resistive line may also be risky... to a point. Sometimes a very long/thin line can save things I suppose. One 'odd' variation that I often think of is perhaps the first dual rotor axial flux machine we ever built. It's on a ridge top (pretty good site) about 400' from the battery (12 Volt) and the line is thin (8 or 9 gauge wire). His runs in overspeed a lot and doesn't furl as early as it should but the line itself has so much loss in high winds that it seems to protect the stator and the machine has been reliable with no real problems now for 7 years or so! In average / low winds, his line loss is not so bad and overall I don't think the long/thin line costs him too much.
'I agree that alot or most are from furling failure. So that asks the question does the furling designs in the current books available really work?'
I tend to think it works quite well. The only failures I've had direct experience with involve machines I've built that simply dont furl early enough and burn out in high sustained winds - or - machines that are not loaded correctly (one case involved somebody hooking it directly to a single resistor, another involved a rectifier burning out).
' Or are people deviating that much from the plans that their furling is never going to work?'
I think about any deviation will change things enough so that it'll likely take a bit of time/tuning to get things right.
'I'm starting to wonder if the current furling design works for 10 foot turbines but not reliable for larger sizes.'
It seems quite reliable on all of the larger machines I've built so far. The first run of my 20' turbine was 8 months straight and I never shut it down once no matter what the wind speed. It did finally fail in very high/gusty winds (measured windspeed nearby was over 100mph) when the blades struck the tower.
'I've preached this before, shorting out the stator may work for a brake IF... and thats a big IF the stator is still working and intact.'
Agreed. And I know there are exceptions, but usually when a stator overheats it warps enough/comes apart enough to jam up the machine anyhow. I know that's not always the case though.
' I lost one turbine from the tail flying around too far and striking the blades, and a second one from the stator overheating..while furled ,until a coil dropped out and then its a runaway. Those blades reached supersonic speeds I'm sure . I found one 300 feet away'
Yikes...
Well I'm surely not arguing against having a brake. I think it's quite a good idea done right. I just want to stress my opinion, that setup right... furling should / can and is well proven to be a very reliable governor. Furthermore, any 'new' wind turbine design is likely going to take a lot of time to get well sorted out. To really know if it's problematic or not - it likely takes a lot of machines in different environments and a lot of time and even then there are bound to be failures. We've been building about the same 10' machine for a long time now and I still make little changes all the time. I try not to change too many things at once though.
'So its like having a car with brakes that only work when the engine is running!'
yes... in this case the engine is a pretty simple beast but agreed, if it becomes disconnected or burns out then some other sort of brake (other than a shot gun) would sure be nice ~ especially on the larger machines.
