Thanks for that. I'll use that to figure the thrust and go from there.
I went and did some more figuring on this deal and I came up with another idea. If I use a compression spring I can build a cylinder with the spring in it and put an adjusting screw in the end of the cylinder. If any of you guys have ever raced stock cars it's called a "weight jack". Just turn the screws on the springs to set the wedge for the track. The more you crank the weight jacks, the stiffer the spring rate. Same principle.
If I do it that way I can go from fully flying to fully furled with only 8" of spring travel. And it will also be a built-in tail stop so the boom can't fly around and hit the blades.
I think I came up with a way to figure the starting point for the spring rate. Let's say you have 12" of rotor offset and you have a 100 lb thrust force. I'm using round numbers for easy figuring. That's 100 lb-ft of torque at the yaw shaft being applied by the rotor. Let's say, for sake of argument, that this is the calculated furling point. The spring loaded tail has to apply that same amount of torque in the opposite direction to keep it flying.
The tail hinge is now the yaw shaft because the hinge has a zero degree angle and the tail hinges directly on the yaw tube. If I attach one end of my compression cylinder on the offset bracket at 12" from the yaw shaft, and the other end to the tail boom, the spring has to have 100 lbs of push to balance the rotor thrust. If the rotor thrust exceeds the 100 lbs it will overcome the 100 lbs of counteracting push on the same point by the spring cylinder, and it will furl.
Feel free to tell me why it won't work :-)
Chris
