Author Topic: fuse size  (Read 883 times)
garyc
fuse size
« on: September 09, 2007, 06:41:46 PM »
On my solar panel label is says... fuse 15amp. Does this mean that I should use a 15 amp fuse? Because if I do the math I only need a 6 or 8 amp fuse. 150 watt panel 24v
« Last Edit: September 09, 2007, 06:41:46 PM by (unknown) »
Nando
Re: fuse size
« Reply #1 on: September 09, 2007, 01:37:46 PM »
USE 15 AMPS
it is ultimate protection.
Nando
« Last Edit: September 09, 2007, 01:37:46 PM by (unknown) »
Re: fuse size
« Reply #2 on: September 10, 2007, 05:56:17 AM »
Make sure that you use conductors sufficient to handle 15 amps and use the recommended fuse size.  If you are forced to use a smaller conductor, use a fuse that will not allow more current through that conductor than it is rated for.  The fuse needs to be the weakest link.  Rich
« Last Edit: September 10, 2007, 05:56:17 AM by (unknown) »
Re: fuse size
« Reply #3 on: September 11, 2007, 02:24:12 PM »
The fuse also protects the panel and wiring from currents driven from other sources - such as other panels in the array, the battery, etc.  It may not be adequate to prevent damage to the panel but it WILL prevent fire.
The value specified is sufficiently above the panel's short-circuit output current that the panel can never blow the fuse with its own output.  So it is there solely to limit damage due to other malfunctions.
« Last Edit: September 11, 2007, 02:24:12 PM by (unknown) »
