hi all,
i have a windy boy 3000 that i am trying to repair. i dont have any grid power, so i thought i might try and get the voltage of my turbine up to that needed by the inverter. around 250 -300 volts dc. i want to connect 3 single phase transformers to the output of my turbine, but am not sure of the best connection method. i found this site which seems to explain the options very well.
http://www.allaboutcircuits.com/vol_2/chpt_10/6.html
the output from the turbine is 3 phase star without the neutral so delta delta looks the only option. i will rectify the output and put some smoothing caps down the line from the rectifier. what will 3 transformers do to the loading of the the blades if anything. i dont want to risk putting a big inductive load across my working inverter which is why i want to do it this way. also i want to try a overvoltage circuit to limit the voltage to the windy boy. think that is what killed it in the first place. i know this is a long winded way to do it but feel it might produce some interesting results. i will use the output from the windy boy to drive a battery charger, and keep the system i am using at the moment seperate. any problems i havent thought about? i have loads of transformers and caps and diodes so shouldnt cost me anything apart from time. i also want to use the data logging option on the windy boy if possable.
cheers
bob golding
