I have an older setup which runs on 32vdc. I don't want to convert it to 12 vdc because all the parts work.
My question is about batteries.
Eight-volt batteries linked in series (4) are hard to come by and expensive, so I have been using 3 x 12 vdc batteries. The charger is an older 32 vdc Charles ferro-resonant. This does not have an automatic feature and tends to boil off the electrolyte. The genset is an old Diesel who's engine electrics, pumps, etc. run on 32vdc. Solar panels are easily configured into multiples of 12 volts, so I'm good there. I also have a smaller stand-alone 12 vdc setup.
I need expert advice on two aspects:
- - What is the downside of charging 36vdc battery bank to only ~32vdc? What can I do to overcome any downside?
- - Is there anything I can buy or build that will shut down the charger when the battery bank reaches ~32vdc? The low tech way would be a timer, but I would hope that there is something that can read the voltage and perhaps switch a relay to stop the charger?
I am away from the setup for no more than a few days at a time, so I don't need to worry about the batteries becoming discharged when I'm away, but I also don't want the charger to keep charging the batteries either.
Gordon
