Author Topic: Would this controller work with a wind generator?  (Read 1588 times)
Matrix1000
« on: June 03, 2008, 07:34:12 AM »
I'm working on a RE system for my 29ft travel trailer. I've got one Unisolar 64 solar panel and two trojan t-105's and a small homemade wind generator that doesn't produce much.
I need a charge controller and I'm considering a MorningStar SunSaver Duo because it has a remote monitor and looks like it can handle the amps for another panel or two.
http://www.morningstarcorp.com/products/SunSaverDuo/SunSaverDuo.shtml
Would I be able to use this controller with a wind generator? My next choice is between a MorningStar Tristar C-45 or a Xantrex C35/40. I've read that some are using the C35/40 for wind with a diversion load but was wondering if anyone could shed some light on the two MorningStar controllers.
« Last Edit: June 03, 2008, 07:34:12 AM by (unknown) »
snowcrow
Re: Would this controller work?
« Reply #1 on: June 03, 2008, 05:50:53 AM »
  The MorningStar SunSaver Duo doesn't have a diversion mode that is needed for wind power.  The Tristar C-45 is a good choice but is more costly than the Xantrex C35/40.  The Xantrex C35 is around $100, Xantrex C40 around $125, while the Tristar C-45 is about $180, all prices are without meter.  I guess it depends on how many solar panels you plan to add, and if you're mobile or parked for good.
  I've been running my 27ft travel trailer on four marine deep cycle batteries, charged with a Xantrex C35, from one BP 80watt panel and an Air-X.  Its been up and running for four years now with no problems.
Blessings, Snow Crow
« Last Edit: June 03, 2008, 05:50:53 AM by (unknown) »
Usman
« Reply #2 on: June 03, 2008, 05:23:00 PM »
Both work great in 'diversion control' for wind tubrines and solar or any other charging source upt 100% rating, without downsizing.
Much better in terms of extra options, as compared to Xantrex C series.
Thanks, Usman.
« Last Edit: June 03, 2008, 05:23:00 PM by (unknown) »
Matrix1000
« Reply #3 on: June 05, 2008, 12:11:42 PM »
Thanks for the info! Sounds like your setup is almost exactly the same as what I'm trying to setup.
I'm still looking for a GE ECM 1HP motor for my home made wind gen but I plan on welding a 20ft steel pole to a 24x24 1/4 in steel plate _|(with triangle supports between the pole and the plate) for the wind gen and just parking the trailer tires on it when I'm onsite to keep it vertical.
I've been looking for a vent cover ventilation fan for a diversion load but haven't found one with a motor that might work.
« Last Edit: June 05, 2008, 12:11:42 PM by (unknown) »
snowcrow
« Reply #4 on: June 05, 2008, 07:11:19 PM »
  As for your diversion load, DC motors don't much like the output from diversion controller and wouldn't use enough power to keep the batteries from over charging.
  I swapped out the AC element for a DC element in my hot water tank, of course I am parked up in the north woods of Vermont, with no grid power nearby. A 300watt DC element should work fine if you go with a C-35, and a 600watt if you go with the TS-45
« Last Edit: June 05, 2008, 07:11:19 PM by (unknown) »
ZooT
« Reply #5 on: June 09, 2008, 01:08:31 PM »
Quote:As for your diversion load, DC motors don't much like the output from diversion controller
No, they sure don't.....they either just buzz or jerk....and that can't be good for either the motor or the charge controller....
« Last Edit: June 09, 2008, 01:08:31 PM by (unknown) »
