Ghurd, can you explain more about the timers you mention? Do they provide the Lorentz the signal it is looking for but just sloppy on timing? I can deal with (somewhat) sloppy timing. What kind of power do they need?
Jacobs: So if I understand correctly, with the SS7 or ST1 I would need to provide power equal to 4amps at 12VDC? That's do-able. It's a fair amount of power but not unreasonable. I guess I'm hoping to find a lower power solution.
ULR, I wouldn't want my pump pumping against a closed valve all day, so I want a timer to tell it when it's time to pump. You mention a battery powered quartz clock timer. Do you know the output of these? Is it a pulse or a continuous signal and would it be compatible with what the Lorentz controller is looking for for input?
dnix71, yeah, gravity would be ideal but the field is only a few feet lower than the cistern, and about 600 feet away, so there won't be enough pressure.
la7qz, that sounds like a good solution, but like for ULR do you know the output signal and would it be compatible with what the Lorentz controller is looking for for input?
Chuck, I didn't know the Lorentz controller converted the DC into AC. That's interesting. Yes, for my system, the more panels the more pressure. As you say, wiring a timer to the shutdown circuit is the way to go; do you have any experience doing that? Do you know what the output of the timer needs to be (volts, amps ??) in order for the Lorentz controller to respond?
Thanks everyone for your responses, very helpful!
