Author Topic: Battery cable guage  (Read 1875 times)
Dave B
    • DCB Energy Systems
Battery cable guage
« on: October 30, 2009, 08:48:21 AM »
Searching for suggested battery jumper size is resulting in vague answers. I'll be running 8 6 volt l-16s for 24 volt with a DR3624 inverter / charger. The Xantrex manual states 4/0 for the controller cables and battery run which will not be more than 10' to my disconnect. I guess I would assume no less for the connecting cables between batteries. I'm not looking for a cheap way out but just a little confirmation which seeems tough to find. Any suggestions with this and possibly a good source for the cable and ring connectors would be much appreciated. I'd like to make my cables. Thank you,  Dave B.
« Last Edit: October 30, 2009, 08:48:21 AM by (unknown) »
DCB Energy Systems
http://dcbenergy.com/
hydrosun
Re: Battery cable guage
« Reply #1 on: October 30, 2009, 09:05:08 AM »
Since you are doing 2 strings of 4 batteries, each string is only providing 1/2 the amperage. So you should be able to use 2/0 wire for the interconnects. Be sure to connect the wires to the inverter at opposite corners of the battery bank to keep the current pathways even through the two battery strings.
Chris
« Last Edit: October 30, 2009, 09:05:08 AM by (unknown) »
DanG
« Reply #2 on: October 30, 2009, 12:54:19 PM »
Whoa - I just checked my favorite vendor that I've done local pickup from, and heavy wall plated 4/0 lugs are $2.10 a pop (small pain) and 4/0 cabling has gone into nose bleed large pain territory. (waytekwire)
Watch eBay and Craigslist for bulk wire buys, I snagged 25' of used four-conductor 4/0 (2000v with three 0awg grounds) delivered for $1.50 a foot (100+ feet) ... Just had to get the wife to hold the heat gun to soften the armored sheath so I could razor it apart to get the wire out.
Welding cable is an option but you need to find lugs rated for fine-stranded cable, and choosing used welding cable means flaws in the sheathing. Finding copper bar stock from battery interconnects is a option. In anyway you accomplish this would be a good idea to have fuse (Doomsday prevention) as near to the battery as possible...
« Last Edit: October 30, 2009, 12:54:19 PM by (unknown) »
FishbonzWV
« Reply #3 on: October 30, 2009, 02:51:35 PM »
Hi Dave,
I have 11 feet of 2/0 4 conductor fine strand copper that I don't need.
I used it on my battery bank (8-6V Group 27 AGMs).
If you would like to have it for the shipping cost shoot me an email.
It's an SO type cable so I'll have to strip off the outside coating.
I'm trying to clean out stuff I don't need anymore.
Bonz
« Last Edit: October 30, 2009, 02:51:35 PM by (unknown) »
H.F.Fisher 1925-2007
Volvo farmer
« Reply #4 on: October 30, 2009, 03:53:44 PM »
I have the exact same battery setup and voltage. We went 2/0 on the interconnects and 4/0 on the inverter run. I'm pretty sure that is the correct sizing.
« Last Edit: October 30, 2009, 03:53:44 PM by (unknown) »
Less bark, more wag.
« Reply #5 on: October 30, 2009, 03:56:30 PM »
I think it was Stephen Fahey (Sparweb) who posted a link to the NEC guidelines for solar installations.  I printed it out and have it at home, but don't have it handy at the moment.  If you were to use 2/0 wire for the battery interconnects, then I think you would be required to fuse them accordingly as well.  I would likely opt for 4/0 all the way even though it is a pain to work with and the costs are significantly more.  That way I could just fuse the positive ends of cables from the bank to the inverter with a fuse rated for up to 4/0, about 250 Amps which should be fine for exposed THHN copper cable, and have a breaker at the DR3624 of about a 175 to 200 amps at the inverter, although I would definitely double check all of this before I did so.  I would also fuse any other cables from the battery bank at a rating appropriate for the cables size.  Rich
« Last Edit: October 30, 2009, 03:56:30 PM by (unknown) »
Volvo farmer
« Reply #6 on: October 30, 2009, 05:21:03 PM »
My system was installed by a professional, to 2006 NEC code, and passed local inspection. There are no fuses other than a 250A breaker before the inverter in the DC distribution box, and of course all the charging sources and controllers have appropriate sized breakers.
Either something has changed in three years, or my installer and inspector missed something, or there are no fuse requirements in the battery box itself.
I'd be interested to see that link to the NEC code if anyone finds it.
« Last Edit: October 30, 2009, 05:21:03 PM by (unknown) »
FishbonzWV
« Last Edit: October 30, 2009, 05:57:25 PM by (unknown) »
« Reply #8 on: October 30, 2009, 06:49:12 PM »
There were changes in the 2008 NEC relating to solar. If you did your install earlier, then they didn't apply then.
Send me an email. dnix71 yahoo. I have the current NEC in pdf form if you want it.
« Last Edit: October 30, 2009, 06:49:12 PM by (unknown) »
Dave B
« Reply #9 on: October 30, 2009, 11:46:42 PM »
Wow,
  What a great response, thank you. More searching seems to prove out that 2/0 is fine for the interconnects but 4/0 is required for the battery to inverter and disconnect. I'm going to check with local suppliers just to get an idea on costs. Who knows, maybe pre-made will be the best. Anyone who has purchased battery supplies from a particular company with good service and reasonable pricing I would sure appreciate the contact information. Thank you again to all, Bonz (you've got mail)  Dave B.
« Last Edit: October 30, 2009, 11:46:42 PM by (unknown) »
DCB Energy Systems
hydrosun
« Reply #10 on: October 31, 2009, 11:34:46 AM »
I know in the past people would use welding wire and make ends with copper pipe crimped and soldered and flattened and drilled. I've got a big crimping tool and get cast copper lugs. The soldered lugs are probably better.
Chris
« Last Edit: October 31, 2009, 11:34:46 AM by (unknown) »
