sorry to post again but i forgot to give you an answer to your question....yes this is how you wire it in star...all the coils should be laid in the same manner...you have to test them with a volt meter to see how many ohms of resistance are in each coil...whatever your first reading is, then you go to the next one, if it is higher, then you are doing it right...if the reading is lower, then you have to turn the coil upside down as it would be wrong...so, what you have is for three phase star configuration....i would suggest you go to a post by ifred on "Solar and large amp rectifyering stuff" (that i how it is spelled) it has some good diagrams and there is some comments and photo's of just what you're looking for....you're on the right track.........pickster
