Author Topic: is there any thing usefull  (Read 890 times)
thumbnail101
« on: February 08, 2005, 03:21:49 AM »
I have an old 17" monator, is there any thing
use full in them, or throw it to the road??
also I have a 90v dc motor, 3 1/2"*6"
just wondering what size of prop would
be adequate to run such a motor.
I think i would be enough to run one light
and a 75watt fan motor for my blower on
my fire place..I now i would have to
run a diferent shaft to it for the load
the prop will have on it..
thanks
Mark
« Last Edit: February 08, 2005, 03:21:49 AM by (unknown) »
Chiron
Re: is there any thing usefull
« Reply #1 on: February 08, 2005, 08:20:26 AM »
There are some useful parts in old monitors, mostly useful for repairing other old monitors. Unless your into electronics experimenting or want to go to the trouble of scrapping it for the Copper and Aluminum it's most useful purpose is probably as a doorstop.
« Last Edit: February 08, 2005, 08:20:26 AM by (unknown) »
« Reply #2 on: February 08, 2005, 08:33:38 AM »
The most usefull things that I've gotten from dead monitors is...
400 volt capaciter
Bridge rectifier
Degausing coil has a fair amount of magnet wire
The flyback transformer is sometimes fun to play with
Power socket where the power cord plugs in
  this socket often has a Power conditioning circuit built in
Some stuff you can use, but not real usefull.
« Last Edit: February 08, 2005, 08:33:38 AM by (unknown) »
stop4stuff
« Reply #3 on: February 09, 2005, 01:04:26 AM »
i've found quite a few high value, low voltage capacitors in both monitors and pc power supplies...
in a monitor i scrapped yesterday, i found a AN7805 5v regulator...
small generator + big cap bank + voltage regulator + white LEDs = home lighting
more on that later :)
have fun,
paul
« Last Edit: February 09, 2005, 01:04:26 AM by (unknown) »
