Author Topic: $1 counter ?  (Read 1439 times)
$1 counter ?
« on: December 15, 2005, 05:45:12 AM »
I was in the local dollor store (wife getting chritmas wrap and such) I got some sandpapper, glue, 3 big calculators and I couldn't resist this littel step counter.
You hook it to your belt and it counts steps up to 99,999. It apears to have a small pendulum that swings up and down. Not sure what type of scensore picks up thisd movement?
I was thinking maybe the could be modifide to become a tack or something? Seems to work well and even comes with a AG13 button cell battery rated to opperate this thing 24 months.
OH well it was only a buk?
« Last Edit: December 15, 2005, 05:45:12 AM by (unknown) »
  • Moderator
Re: $1 counter ?
« Reply #1 on: December 15, 2005, 01:16:19 AM »
Norm re-did some $1 calculators to counters.
Works quite well.
Problem was they couldn't count fast enough for some things.
Norm would be all over this one, but his 'puter busted.
« Last Edit: December 15, 2005, 01:16:19 AM by (unknown) »
ubud
Re: $1 counter ?
« Reply #2 on: December 15, 2005, 06:14:13 AM »
Mount it on your coil winder to count turns.
« Last Edit: December 15, 2005, 06:14:13 AM by (unknown) »
Re: $1 counter ?
« Reply #3 on: December 15, 2005, 06:23:46 AM »
Jerry,
       Right on Jerry...here it is:
http://www.fieldlines.com/story/2005/4/22/153937/685
  Only thing they can't count very fast maybe not
over 200 rpm. but would be okay for a manual coil
winder counter unless you're really fast!
  Then for a rpm counter like on a mill you can use:
http://www2.suite224.net/~peppysue/
disadvantage with this one, it shuts off after
5-10 minutes and you lose the data.
                 ( :>) Norm
« Last Edit: December 15, 2005, 06:23:46 AM by (unknown) »
not quite right
« Reply #4 on: December 15, 2005, 06:36:11 AM »
Not quite right the problem with the calculator..
...wasn't !!
 The mechanical contact would float aat about 100 rpm I needed....(still do...) some
magnetic reed switches or how to use the optical counters in a $1 mouse....Yes you can even buy
$1 mouse at Dollar Tree.
                ( :>) Norm
« Last Edit: December 15, 2005, 06:36:11 AM by (unknown) »
