Author Topic: Wiring a Rectifier  (Read 1079 times)
Ding123
Wiring a Rectifier
« on: January 19, 2006, 12:21:58 AM »
I wired my 4 prong rectifier ,to my gennie. I want to know if it is ok to have
a reading in AC and a reading in DC , as well. If this is a normal occurance can someone please let me know.Thank you.
Editor thinks you should try to provide more info, your pictures don't say much about how the bridge is wired [see only its back side] , the readings you see, etc [ they are too blurry for me to read]. Comment  with more info and try to give as much info as possible or it is futile trying to get help.
« Last Edit: January 19, 2006, 12:21:58 AM by (unknown) »
seanchan00
Re: Wiring a Rectifier
« Reply #1 on: January 18, 2006, 05:46:08 PM »
What you show seems to be a bridge rectifier. Two opposing prongs are for AC wires from the alternator and you will see AC if your alternater is generating AC. The remaining two prongs will be your required DC output. One is usually labelled + and the other neg( - ). This will be measured DC. I am not sure how you measure AC in your rectifier. I measured my alternator AC by connecting one of the STAR leads to the three leads wired together. I have never tried to measure AC at the rectifier.
SeanChan.
« Last Edit: January 18, 2006, 05:46:08 PM by (unknown) »
Shadow
« Reply #2 on: January 18, 2006, 05:53:24 PM »
You should get AC up to the rectifiers, Then DC with you positive and negative outputs.
« Last Edit: January 18, 2006, 05:53:24 PM by (unknown) »
stop4stuff
« Reply #3 on: January 18, 2006, 06:08:52 PM »
if you're measuring the dc output and get an ac reading, this is because the output is a pulsed dc, to get a true dc reading, you need a capacitor across the +ve & -ve of the rectifier
« Last Edit: January 18, 2006, 06:08:52 PM by (unknown) »
« Reply #4 on: January 18, 2006, 06:20:24 PM »
I'm assuming you have something like this:
 - Genny hooked to the AC terminals of the rectifier.
 - Meter across the DC (+, -) terminals
 - No battery or other load connected.
 - Spinning the genny by hand or something.
 - DC and AC readings taken with no changes
   to setup except for switching between a
   DC and AC voltage scale.
If that's the case it's fine to have readings
on both the DC and AC scales - and for them
not to match.
Your bridge rectifier's output is pulsing DC.
Your multimeter's DC scales are just the meter
movement connected to the probes through a big
resistor (selected by the scale you chose) to
turn the voltage into a proportional current.
The meter movement responds to the current -
averaging it out over the cycle.  Pulsing DC
has a non-zero average DC voltage and that's
what you read.
The AC scale will be similar, with three changes:
 - A capacitor is inserted in series, to eliminate
   any response to the DC component of the input.
   (Now it only responds to the CHANGE in voltage.)
 - A pair of diodes are inserted - one in series
   with the meter coil, one (pointed the other
   way) in parallel with the series connected diode/
   coil combo.  This causes the meter to respond to
   one half-cycle of the voltage change and ignore
   the other.  (A bridge rectifier would let it
   respond to both half-cycles but that's unnecessary).
 - The scaling resistors (and scale markings) are
   different - so that when connected to a sine wave
   of power line frequency (or pretty much any frequency
   above that) the meter will show the RMS equivalent.
Since your DC is pulsing, the meter will show a non-zero
value when set to the AC mode also.
Hang a bigcapacitor across the bridge and the DC reading
will go up somewhat - from the average to the peak -
while the AC reading just about goes away.
Hang a battery (of a value below the peak) across the
bridge and it will be charged by the genny-bridge
combo - and will drag the peak voltage down.  Then the
AC reading will show the small ripple from the charging
current's voltage drop through the battery's series
resistance, while the DC reading will show the battery's
voltage plus the average of the ripple.
« Last Edit: January 18, 2006, 06:20:24 PM by (unknown) »
Ding123
« Reply #5 on: January 18, 2006, 08:02:28 PM »
Thank you very much Editor,Sean Chen,Ungrounded Lightening Rod and Shadow, and to anybody else who took time to answer this question.WOW! you guys really got it together....thank you
« Last Edit: January 18, 2006, 08:02:28 PM by (unknown) »
