The wind mill follows the wind velocity which has a cube power, or V^3 facto, so if you double the wind velocity the power will be 8 times higher.
If one plots this curve, one will see that every time the wind doubles in velocity the power goes 8 times, so if you have 2 m/s and wind goes up to 4 m/s you have 8 times the energy that is available at 2 m/s and if the wind goes to 8 m/s now the wind mill can produce 64 times the energy available at 2 m/s.
If one has a GIZMO that follows that curve, it needs to follow the peak power generated at every moment of time.
This GIZMO is a Maximum Power Point Tracking controller that detects the peak power and adjusts its load to the wind mill to take that maximum power available at every moment of time and since the wind varies, the energy available varies wild, so the controller with MPPT capabilities varies the load following that wild behavior.
MPPT controllers need high voltage and those that have tried to use them with 1/2 wind mill efficiency find them useless -- which is logical in this case --
For a good MPPT controller to attain its best performance the wind mill needs to have a high voltage capability -- so if the load is 10 times larger than the wind mill internal resistance + its inductance (though careful here) the theoretical capability will be that the controller can obtain 90 % efficiency -- depending on how good is the MPPT circuit this efficiency may run a few point lower.
If the load is 5 times the generator impedance, then the efficiency may run around 80 to 83 %
How the MPPT operates: a good circuit will measure the voltage and the current loading the controller; and the controller starts varying the current up/down finding the behavior of the voltage that may go up/down, if the current is brought up and the voltage still is up or continuing up, then the controller keeps bringing the current up, until the voltage starts to come down, at this point the controller may reduce the current and see the voltage behavior and the UP/DOWN is continuously testing this voltage and adjusting the current.
As a result the energy available is harvested at its maximum peak always following that cube power curve of the wind.
MPPT to work needs to have a generator source that has a limited torque source.
With this statement I made, any one, NOT an electrical or electronic expert knows, why this requirement for a limited torque source.??
Nando
