Author Topic: load testing  (Read 1286 times)
dscheckman
load testing
« on: June 06, 2006, 12:16:56 AM »
Hello, I need a cheap, easy  way to test the output of a F&P smart drive rectified to DC driven by hydro. I'm hoping for 500 watts. Has tested to spec open voltage. Thanks for any suggestions.
« Last Edit: June 06, 2006, 12:16:56 AM by (unknown) »
jimjjnn
Re: load testing
« Reply #1 on: June 05, 2006, 06:45:33 PM »
Try light bulbs. Remeber resistance of light bulb changes with temperature of the filament.
« Last Edit: June 05, 2006, 06:45:33 PM by (unknown) »
adelaide
Re: load testing
« Reply #2 on: June 05, 2006, 07:48:16 PM »
hi do u know what the wire sise is (.6 .8 1mm? )
 how u wired it sp or p ?
 estmate of rpm?
 and voltage u will use.
i can give u some figgers which should be close if wire is thick etc
« Last Edit: June 05, 2006, 07:48:16 PM by (unknown) »
commanda
Re: load testing
« Reply #3 on: June 05, 2006, 08:22:56 PM »
Been there, done that. Read my diary.
I used jug elements in a bucket of water.
« Last Edit: June 05, 2006, 08:22:56 PM by (unknown) »
commanda
Re: load testing
« Reply #4 on: June 05, 2006, 08:25:39 PM »
There's also this spreadsheet I did.
http://www.otherpower.com/images/scimages/2006/09590030sxc.pdf
« Last Edit: June 05, 2006, 08:25:39 PM by (unknown) »
Re: load testing
« Reply #5 on: June 05, 2006, 08:39:23 PM »
amanda i ment to ask before , was  the F&P gen in your test rewound?or was it factory windings?
« Last Edit: June 05, 2006, 08:39:23 PM by (unknown) »
commanda
Re: load testing
« Reply #6 on: June 05, 2006, 10:11:10 PM »
Absolutely stock 80S.
« Last Edit: June 05, 2006, 10:11:10 PM by (unknown) »
fred480v
Re: load testing
« Reply #7 on: June 06, 2006, 06:17:22 PM »
we have a dyno. tester that applys a load to electric motors up to 800 hp.. we prime move a gen. then load gen with salt water tank, after lots of testing we found 36oz. of salt per 50 gal.of water worked best. you could break that down to say 5 gal. of water & use. that should work good for you
                fred 480v [ it's not magic]
« Last Edit: June 06, 2006, 06:17:22 PM by (unknown) »
