Hello everyone,
I'm making my first windmill (7ft,24V) for friend by this way I want to start small and learn.
I have been looking around for a regulation circuit but they are very hard to find.
Most of the controllers are for little load or do not use a proper battery charge cycle. Except for the Xantrx C models but they are expensive.
So I tought let's create one.
I'm studying electronics so I know a great deal about it.
I'm going to base my model on some properties of the Xantrex and maybe advance a little.
The properties I value most and that I will try to implement are going to be:
- Proper battery charge cycle(For longer battery use).
- Dump load regulation(even when charging: use all power generated by the mill).
- Load control to keep the mill at a proper speed(Use a tachometer vs current system).
Some extra properties might be:
- Voltmeter(output voltage windmill on a display)
- Ammeter(output current windmill on a display)
- Wattmeter(output on a display)
A Microcontroller will control the system.
The display for the extra properties might be with a selection switch.
If anyone has any other must have suggestions, Doubts or Circuit ideas for this controller feel free to reply.
If I get the protorype working properly and if there are enough candidades I might consider to have the print made by a firm.
