Author Topic: Control circuit to switch on LED's at dusk  (Read 7835 times)
(unknown)
  • Guest
« on: August 09, 2007, 10:48:07 PM »
Hi All
I'm totally new to here but I have an idea to build (for starters) a small solar charger that will power a 12 volt led lamp which would switch on at dusk and off again at dawn. Does anyone have a circuit diagram for a unit like this? I've googled the net but found nothing. Also, would I need a charge controller for a simple circuit like this? Thanks in advance for any help/advice that anyone can give me on this.
« Last Edit: August 09, 2007, 10:48:07 PM by (unknown) »
RogerAS
Re: Control circuit to switch on LED's at dusk
« Reply #1 on: August 09, 2007, 05:36:41 PM »
Easy!
Look at my files. I have a tracking circuit that uses photo resistors and op amps to drive the tracking. You don't need all the other stuff.
All you need is a single op amp like a 741 and a photo resitor and one mosFet. Drive the circuit with the rechargeables that will power the LEDs.
Do a net search for light sesitive circuits if you don't like my little thing or can't figure it out.
Hoping to help.
« Last Edit: August 09, 2007, 05:36:41 PM by (unknown) »
etownlax
« Reply #2 on: August 09, 2007, 07:18:52 PM »
http://www.uoguelph.ca/~antoon/circ/actrelay.htm
Take a look at that... might be something you would want.
I don't think it takes much power. to run.
Even simpler would be a photo transistor and a battery and relay all in series.
-Randy
« Last Edit: August 09, 2007, 07:18:52 PM by (unknown) »
etownlax
« Reply #3 on: August 09, 2007, 07:20:17 PM »
well something like that... (that would turn it on during the day(not what you want))
-Randy
« Last Edit: August 09, 2007, 07:20:17 PM by (unknown) »
« Reply #4 on: August 09, 2007, 10:14:06 PM »
I have built a similar comparator circuit with a low power op-amp and it has performed reliably for a long time.  There is a cadmium sulfide light variable resistor on one of the legs, and two high value resistors as a voltage divider on the other.  It draws a fraction of a milliamp when off.  All it turns on is an LED, but one could run the output to a FET to power a larger number of LED's.  Rich
« Last Edit: August 09, 2007, 10:14:06 PM by (unknown) »
FishbonzWV
« Reply #5 on: August 10, 2007, 05:04:07 PM »
Diskman,
Unless you just want the 'thrill of victory' for building your own, look at this.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90729
It's on sale now for $4.99.
It probably isn't 12v but you could reverse engineer it for the layout. I don't think it's got a contoller in it...they just sized the batteries and PV for a full charge over the daylight hours.
Shoot, you can't even buy the nicads for 5 bucks.
I've got one and it stays lit til dawn.
Fishbonz
« Last Edit: August 10, 2007, 05:04:07 PM by (unknown) »
H.F.Fisher 1925-2007
  • Moderator
« Reply #6 on: August 10, 2007, 05:48:23 PM »
Small 12V solar goes great with a PB137ACV. Cheap and simple.
I think this will work for the switch.  Didn't try it. It is a cross between several online versions.
Might need to right click the graphic and choose 'view image'.
« Last Edit: August 10, 2007, 05:48:23 PM by (unknown) »
la7qz
« Reply #7 on: August 11, 2007, 10:00:59 AM »
Hi
Take a look at this post:
http://www.fieldlines.com/story/2007/5/19/51832/4098
Regards,
Owen Morgan
Yacht Magic
St Martin
« Last Edit: August 11, 2007, 10:00:59 AM by (unknown) »
« Reply #8 on: August 12, 2007, 01:22:35 AM »
Sorry Fishbonz,
 I got friends and others do to.. "can't even buy the nicads for 5 bucks" der many can't but many are less than free! LOL
Thank you oh holy Sub-C Bruce Almighty :)
« Last Edit: August 12, 2007, 01:22:35 AM by (unknown) »
« Reply #9 on: August 15, 2007, 01:35:08 PM »
Nothing to lose;
   Ha ha, don't hold me up that high :-D
Fishbonz If you or others who would like to try some of these. Just leave me a note hear and I'll gladly send them over.
However: NTL is the guru on soldering them as well as making LED light posts out of them.
NTL post a few pics so others will be inspired :-)))
Personally I like the older ones, they're built 4x4 using sub-c and are much easier to re-wire.
NTL , Sorry for the long wait , had personal biz to attend :-(
« Last Edit: August 15, 2007, 01:35:08 PM by (unknown) »
  • Moderator
« Reply #10 on: August 15, 2007, 01:39:43 PM »
(Glad you are back)
« Last Edit: August 15, 2007, 01:39:43 PM by (unknown) »
« Reply #11 on: August 16, 2007, 12:48:54 PM »
Thanks for the shoulder too...
PS, did you find those parts? I need to order 3 more of those controllers.
If you have the time, try hooking up one of those steppers like the one you sent to me, use a quick little adding circuit so the ouputs add togther and send it into a LM317 with the output fixed. Send that into one of your dump controllers :-D .
Oh I used that last one and attached it to the metal $7.00 mole chaser from HF.
On a 10 foot pole latched to the pool.
pretty little LEDs.
Have Fun
« Last Edit: August 16, 2007, 12:48:54 PM by (unknown) »
  • Moderator
« Reply #12 on: August 16, 2007, 12:51:14 PM »
Consider them in the mail.
« Last Edit: August 16, 2007, 12:51:14 PM by (unknown) »
