Author Topic: fetless  (Read 2677 times)
windspeed
fetless
« on: September 02, 2008, 09:57:57 PM »
I pulled this out of a 24 volt controller
could anyone tell me where I could get one or an equivalent
Windspeed
« Last Edit: September 02, 2008, 09:57:57 PM by (unknown) »
spinningmagnets
Re: fetless
« Reply #1 on: September 02, 2008, 05:25:28 PM »
Go to the electric bicycle forum over at "endless-sphere" and ask Fechter, he is the FET guru.
http://endless-sphere.com/forums/viewtopic.php?f=1&t=5306
« Last Edit: September 02, 2008, 05:25:28 PM by (unknown) »
Re: fetless
« Reply #2 on: September 02, 2008, 05:57:42 PM »
All FET's except jfets have 4 terminals. Are you sure it's not a zener?
« Last Edit: September 02, 2008, 05:57:42 PM by (unknown) »
Re: fetless
« Reply #3 on: September 02, 2008, 06:06:32 PM »
The third line of numbers looks like SR
That would make it a rectifier.
« Last Edit: September 02, 2008, 06:06:32 PM by (unknown) »
boB
    • boB
Re: fetless
« Reply #4 on: September 02, 2008, 11:38:45 PM »
It's more than likely this FET...
IXFH80N08  80 Volt  80 Amp
http://ixdev.ixys.com/DataSheet/98810.pdf
(most likely)  but maybe a higher voltage one:
IXFH80N085  (85V) or  IXFH80N10 (100V) IXFH80N15 (150V) etc...
In fact, some distributors have the ISFH80N085 which should work
fine in a 24V controller.
Future Electronics has some in stock but they're like $18 a pop.
http://www.componentsuperstore.com/
boB
« Last Edit: September 02, 2008, 11:38:45 PM by (unknown) »
Re: fetless
« Reply #5 on: September 03, 2008, 12:28:06 AM »
I will go with boB, its an Ixys mosfet. Can't read the last part of the number to get the voltage grade but you can choose that depending on the system volts.
Ixys devices are expensive compared to other manufacturers but they do seem to be tough.
You can find alternatives from other manufacturers cheaper but I would go for a higher spec if you do.
Unless you find what caused the trouble you may have an instant fry with the replacement.
« Last Edit: September 03, 2008, 12:28:06 AM by (unknown) »
DingBat
Re: fetless
« Reply #6 on: September 03, 2008, 05:29:34 AM »
So what's the fourth pin?
I know about Gate, Source and Drain.
« Last Edit: September 03, 2008, 05:29:34 AM by (unknown) »
Re: fetless
« Reply #7 on: September 03, 2008, 07:19:08 AM »
Three are enough for me.
« Last Edit: September 03, 2008, 07:19:08 AM by (unknown) »
BigBreaker
Re: fetless
« Reply #8 on: September 03, 2008, 10:18:09 AM »
Sometimes in a power MOSFET the body and source are left unconnected and both leads are exposed, in addition to the drain and gate.
« Last Edit: September 03, 2008, 10:18:09 AM by (unknown) »
boB
    • boB
Re: fetless
« Reply #9 on: September 03, 2008, 11:43:48 AM »
3 legs and one TAB (mounting, heat sinking tab), are the 4 connections.
Middle leg AND tab are usually the drain and are connected together.
boB
« Last Edit: September 03, 2008, 11:43:48 AM by (unknown) »
Re: fetless
« Reply #10 on: September 03, 2008, 09:02:11 PM »
Yeah, not cheap at all.
http://oemstrade.com/search/IXFH80N20
lists online sellers.
« Last Edit: September 03, 2008, 09:02:11 PM by (unknown) »
GlutealCleft
Re: fetless
« Reply #11 on: September 04, 2008, 04:36:07 PM »
In this case, the tab is on the back, although the front of the tab is covered.  However, because of the damage, you can still make out just a tiny bit in this photo.
However, the "Four Terminals" is generally a function of the package, not of it being a FET.  Look at those available in the SOT23 package.  Three pins, no more. :D
« Last Edit: September 04, 2008, 04:36:07 PM by (unknown) »
