Sea-50? Run away! Run away!
Shouldn't take much googling on 3 forums to get more info on the item and supplier.
I wish they still had the crazy charts and crazy explainations on that site.
I do recall ONE guy had that relay thing and liked it.
Auto-style relays tend to fail soon under any kind of good control. They were not intended for a lot of cycles. Simple to make my circuit drive a relay, just widen the hysteresis and add a flyback diode.
My circuit was not really intended for something that big, but it sure beats a sloppy zener relay driver.
For that kind of money ($169), from me, you could get my kit, extra power fets, And 100A (at 12V) of dump resistors! And still have a bit of cash left over.
It would be more for 100A of 24V resistors.
Not so much a sales pitch as pointing out Better options are available for a lot less total money.
A stray idea.
I don't know if the C-40 over-voltage condition is dependant on a set time, as in "if the voltage is over X for 1 minute, then start dumping".
Could set one of my controllers to less than the inverter trip voltage, and have it dump say 20A(?). The lower charging amps should result in the battery voltage rising above the C-40 threshold voltage more slowly. Maybe that would allow the C-40 to do its job, without tripping the inverter?
