Author Topic: solid state relays  (Read 1041 times)
Rover
solid state relays
« on: January 04, 2009, 04:59:28 PM »
FYI
I was browsing allelectronics.com for surplus, and came across som 40 Amp solid state relays 3-32v trigger at 25 mA for 15$. I'm buying some of them to use with my controller , and a load dumper.
These typically go for a lot more money, and the nice thing about them is the low trigger voltage/low trigger current / high current switching   (can be triggered by most homemade controllers with 5V-12V)
Having screw terminals is a plus, as you don't have to worry about how thick a PC board trace needs to be to handle the switched current.
http://www.allelectronics.com/make-a-store/item/SSRLY-42/40-AMP-SOLID-STATE-RELAY/1.html
« Last Edit: January 04, 2009, 04:59:28 PM by (unknown) »
Rover
boB
    • boB
Re: solid state relays
« Reply #1 on: January 04, 2009, 12:58:43 PM »
I think this is the part they are referring to...
http://www.cosmo-ic.com/ProductDetail-H.asp?title=Solid%20State%20Relay
It looks like it's a triac and good for dumping on the AC side of a turbine
or on the AC output side of an inverter.
Cosmo does have DC MOSFET types too, but they are very low current.
There are some decent DC SS Relays out there that I have seen in the past.
boB
« Last Edit: January 04, 2009, 12:58:43 PM by (unknown) »
Rover
« Reply #2 on: January 04, 2009, 01:31:26 PM »
That was the plan... dump before rectifiers, controled by my stamp, or pic axe.
« Last Edit: January 04, 2009, 01:31:26 PM by (unknown) »
Rover
Opera House
« Reply #3 on: January 06, 2009, 02:59:39 PM »
Provide enough heat sinking for the relay.  These triac units have high insertion losses.
« Last Edit: January 06, 2009, 02:59:39 PM by (unknown) »
Rover
« Reply #4 on: January 06, 2009, 03:16:22 PM »
Yeah, I think I'm gonna end up using them to switch some small AC stuff off of my small HF inverter or find some other use for them
I'm gonna stick to my original plan and dump as needed from DC side, i just couldn't pass these up though.
« Last Edit: January 06, 2009, 03:16:22 PM by (unknown) »
Rover
