Oldmill;
You should be okay, It really depends on the Amp-hour rating of those 2 6Vdc batteries and how big the deep cycle batt is, BUT you should be okay, IF the marine batt is for a trolling motor and those 2 6V batts are similar to the ones from Sam's/Walmart of the golf cart types.
May be a good idea to make sure all 3 three are topped up to correct levels with distilled water before leaving tho.
Both item Panel and controller are good solid brands and you should get a long life out of both.
Cheers;
