In 2009 I changed the stator in my small wind turbine. There was nothing physically wrong with the stator that was in use that had been built back in 2007. Here is a picture of the original stator.
It was a 6 coil 3 phase star configured stator. Each coil had 80 turns of 22 AWG wire and had a DC resistance of 0.45 ohms. DC resistance across two phases was 1.8 ohms. AC peak voltage to RPM ratio was 0.014.
In 2008 I had modified the stator to be used with a boost converter to improve load matching between prop power and alt power. The boost converter operates from 2 m/s to about 6 m/s and then the main rectifiers take over once the alt voltage is above battery voltage.
In 2009 I wanted to try a different design to reduce the amount of copper in the stator and reduce resistance by at least half. I could have just used 2 22awg in hand to reduce coil resistance by half, I had the room. But I decided to try the overlapped coil design that had been discussed many years earlier on this board. I was curious to see how well it would work. After about 3 months of trial and error I was able to determine how many coils and turns I needed for each phase and how to lay them out.
The magnet rotor seperation went from 0.5" to 0.275". Turns per phase went from 160 to 100. Coils per phase went from 2 to 8 so each coil in the new stator would have 12.5 turns. Calculated resistance of a phase based on turns and coil size was about 0.45 ohms. AC peak voltage / RPM ratio was decreased from 0.014 to 0.012 since the resistance had dropped in the new stator and power output would be higher (wanted to keep TSR up to at least 4 at 12 m/s, design TSR is 5 for the blades).
Attached is a picture of the new stator now in use.
Construction details to follow in the next post.
