Author Topic: voltage  (Read 1967 times)
thinkthink
voltage
« on: May 28, 2010, 03:58:43 AM »
should i use 12v,24v,48v?
which should i use?
Thanks   ???
Re: voltage
« Reply #1 on: May 28, 2010, 04:37:12 AM »
which should i use?
Thanks   ???
How long is a piece of string?
That is the context of your question.
Insufficient information to even try to offer an answer
You need to do some research and formulate a sensible question based on your plans / needs.
There is no way anyone can answer this other than "It Depends".
Think it over and repost with some detail and we can certainly help you sort it out.
fabricator
  • My smoke got out again
Re: voltage
« Reply #2 on: May 28, 2010, 12:29:49 PM »
which should i use?
Thanks   ???
18" exactly, and I put little knots on each end so it wont fray.
Re: voltage
« Reply #3 on: May 28, 2010, 05:49:05 PM »
which should i use?
Thanks   ???
I use 1.23579mm just to be sure I have the right twine :)
Tritium
Re: voltage
« Reply #4 on: May 28, 2010, 06:04:34 PM »
which should i use?
Thanks   ???
I am unclear on this. Is it 18" before or after knotting?  ;D
Thurmond
RP
Re: voltage
« Reply #5 on: May 28, 2010, 06:32:44 PM »
According to the emails I keep getting it's more about the "girth".  Now that's a word you don't hear used much except in certain spam emails.
(wonders just how far the thread can shift before a moderator gets annoyed)   :o
zap
  • There's an app for that
Re: voltage
« Reply #6 on: May 28, 2010, 06:45:26 PM »
So far none of the replies have helped much because no one mentioned what color string to use. :-X
