Yes, the tank is a Rheem 80 gal w/ built in heat exchanger wrapped around the lower part of the tank. They run about 1800 plus fees, but this was a $150 Craig's list special that was broken upon installation so it was a real find. The water and the glycol mix never come close. I pulled the broken drop ear brass 90 off the bottom of the exchanger loop, and a standard slip 3/4 street end, 90 slid right on to the copper coil, so I am good to go. Next I have a question about the panel setup but I will post that in another subject. I hope this helps someone in the future. Note, the drop ear 90 that was cracked was soldered not only on to the coil loop, but was spot brazed to the side of the tank as well, so it took some HEAT!!!! But it did slide off.
