Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Solar
damaged sunpower panels
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: damaged sunpower panels (Read 31867 times)
bamfords54
Newbie
on:
June 09, 2010, 09:03:35 PM »
question for everbody, The company I work for has 3 or 4 sunpower 220 watt panels sitting in the shop with shattered glass. Is there any way to replace the glass or use these some other way? I was thinking about building a frame to mount them in and covering it with tempered glass. any ideas?
Logged
SuperHero Member
Re: damaged sunpower panels
Reply #1 on:
June 11, 2010, 03:41:03 PM »
If they still put out in full sun, you could build a box to house them. The glass needs to be low iron tempered. It doesn't have to be the same size as the panel, the box it built to accomodate the glass you buy. Those panels were over $700 new probably.
http://cgi.ebay.com/Commercial-Low-Iron-Front-Solar-Panel-Glass-/170497670171?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item27b273fc1b
is an example.
The box needs to vent so you don't condense water on the panels.
Can you take them outside and load test them?
Logged
SuperHero Member
Reply #2 on:
June 12, 2010, 03:50:44 AM »
That sounds like fun . the glass should be bonded at the frame . This is one time when the backing panel with be important . What voltage /current can ou still see from the panels ?
Logged
bamfords54
Newbie
Reply #3 on:
June 14, 2010, 07:26:22 PM »
I did't get a chance to test for volts or amps yet, as we have been very busy. as soon as I get a chance I'll check and post back. still don't know for sure if I can even have them,but hopefully
Logged
Print
Pages: [
1
Go Up
« previous
next »
Solar
