No laughs, just welcome aboard.
Scale down the voltage to the battery voltage you choose. Let's say 12V for the sake of the example, and it's the most common anyway.
If 108V turns the motor at 2000 RPM, then logically turning the motor at 2000 RPM, you might expect to see about that much voltage (not exactly, usually a bit less).
To turn it fast enough to get 12 volts, then:
12/108*2000 = 222 RPM. Probabaly a bit faster in reality.
That speed, 222 RPM, is the cut-in speed of the motor - now acting as a generator. It will be producing enough voltage to start to charge the battery. It sounds reasonable enough so you probably have something worth trying. A great start to experimenting and trying out your ideas.
Good luck!
Here's a link to the FAQ on the topic, too.
http://fieldlines.com/board/index.php/topic,143574.0.html
