Hello, due tot he winds over the past few days in Chicago, 3 out of 4 wind PMA wind turbines crashed to the ground. So, now I am planning on building a larger, 8ft turbine. I had it tied into the grid using a 1000W grid tie inverter from China. Now, your thinking that this is illegal, but I need to tell you that I did do the paperwork with the utility company and they did come out and due an acceptance test, and it did pass. My question is, I want to regulate the voltage so that I can get 24-27volts no matter how much voltage I produce. The inverter has a amp limit of 60 amps. Does anyone know where I can get a regulator that can regulate high voltage to 24-27V? Thank you.
