so lets say you get some UL approved panels, if you want to tie to the grid for a battery-free operation would you have to have a professional installation? Does the power company install a separate meter?
I think that this varies from state to state and even city to city.
Here in MT, you can put in your own grid-tie system.
You have to get an electrical permit ($40) and it has to be inspected as part of the permit.
Once you have finished installing the system and have the permit signed off, you call the utility (Northwestern Energy in our case), and they come and install a net meter.
We did this, and it all went very smoothly. The system install is pretty easy these days as long as you do a little homework beforehand and have a little wiring experience. The inspector and NW power people were all very cooperative and very prompt.
The way net metering works here, the meter runs "backward" when you are generating more power than you use, and "forwards" when the grid is supplying you power. You pay a regular utility bill (same rates as anyone else) for the NET power you use.
If we generated more power over a full year than we used, the utility zeros out the account and does not pay for the excess power we generated. Because of this, we sized our system so that it comes fairly close to giving us a net zero for the year, but will never go below zero.
All the details on planning, installing, living with our system:
http://www.builditsolar.com/Projects/PV/EnphasePV/Main.htmI understand the appeal of being fully off grid -- its an appealing lifestyle thing. But, its not without its down sides -- much more expensive system, much higher system maintenance due to the batteries, lower system efficiency due to the batteries, high battery replacement cost, having to cover all of your power needs with your own system rather than having the grid for backup. Its all stuff you should consider carefully -- a grid-tie system is essentially an install it and forget it system -- with a off grid system, you are the power company and you have to take on all the responsibilities that go with that -- this is appealing to some people, but not for everyone.
From an economic point of view, grid-tie systems in most areas have a low but positive return (ours earns about 5% on the money we invested). I think its unlikely that when you include high initial costs and battery replacement costs that a off grid system will ever earn a positive return --the benefits are more along the lines of the off-grid system allowing you to live where you want to and to be independent of the utility folks.
From an economic point of view the best deal is conservation and efficiency. For us, when we added up the numbers for the bunch of conservation projects we did and compared it to the savings and cost for the PV system, the conservation projects were 10 times more cost effective than an inexpensive, self installed PV system!
Gary
