Those are not the best choice for a "normal" system, especially if you intend to change anything later.
They are probably intended for grid tie.
The Battery clamps the panel voltage down to battery voltage. Until the controller decides the battery is at regulation voltage, when the controller opens the circuit.
In a 12V system with a normal controller, the controller then has 37V on its input which is past the max allowable on most, and the controller blows up.
In a 24V system with a normal controller, the panel voltage is not high enough.
In a system with a MPPT controller, future changes or expansion will not be simple because those panels are unusual.
In a nut shell, they are not good for 12V, 24V, or a starter system with MPPT.
