Does it vibrate at about the cut in RPM,
or when the RPM is faster or slower than about cut in?
If it starts to vibrate at an RPM faster than it was going when the blades would hit the tower, it could be the force bending them back to hit the tower is now bending them back more, and they can start to "flutter".
When my PVC blades flutter, it makes a higher frequency buzzing noise from the blades. When this happens the output amps go down, even if the wind speed increases.
Because it is a brushed DC motor, it is not likely to have the lower frequency "growling" sound that travels down the tower, which is more common with AC output machines.
The vibration from AC output machines also tends to be worst at about the cut in RPM.
Not sure if any of that is important.
