Hi Jarrod,
Lovely work, I like the look of your new stator bracket.
Ive been working with Dan Lennox on a bit of software called the power Dashboard which will solve all your measuring and logging problems.
You connect the Davis directly to a Labjack or any Data acquisition module along with a shunt from the turbine AC wires and a transformer for voltage and RPM samples.
You can see all parameters : Volts, amps, RPM, windspeed and direction, watts out, daily average, weekly and yearly too.
It logs everything and can also allow remote access and shut down control so you can see how your baby is doing when away and send it control signals.
It should be ready in a month or so and is designed specifically for axial flux machines which Dan has built (see the forum).
It might solve lots of your problems- I know its doing that for me!
Good luck with the rebuild
Richard
