Author Topic: Battery heat sensor  (Read 3415 times)
TrackerJack
Battery heat sensor
« on: May 20, 2011, 11:47:34 PM »
String of 24/ 2v. in two rows. Where's the best spot to place the heat sensor. What battery, top or side... Thanks
bob g
    • microcogen.info
Re: Battery heat sensor
« Reply #1 on: May 21, 2011, 02:37:08 AM »
i would pick one of the center cells, and connect to the negative terminal if possible.
bob g
Volvo farmer
« Reply #2 on: May 21, 2011, 08:25:55 AM »
I think I have four of those darn things now. MX60, Classic, C40 and C60. I just shove them all down in between batteries, somewhere in the middle. I like to rotate batteries every few years to move the end cells to the middle and that would be a real pain with the sensors glued to batteries.
Less bark, more wag.
TrackerJack
« Reply #3 on: May 22, 2011, 12:40:15 AM »
sounds good
madlabs
« Reply #4 on: May 22, 2011, 10:29:22 AM »
I used a hose clamp to connect my sensor (lm34 in a brass tube) to my battery post, then wrapped it with insulation.
Jonathan
PeterDe
« Reply #5 on: June 22, 2011, 10:21:31 AM »
Since I just read this, may I ask on what type of battery are you measuring the temperature, and why are you doing it?  What information, or benefit from the temperature information re you trying to gain or obtain?
My question may sound foolish, but there are a variety of reasons for wanting to know battery temperature.
Thanks.
PeterDe
Airstream
« Reply #6 on: June 22, 2011, 11:30:45 AM »
Sounds like you've found a question to fit your answer...
Care to share the variety of reasons up front without fishing for responses?
TrackerJack
« Reply #7 on: June 22, 2011, 10:51:17 PM »
PEDE .......  It' just that I want to make sure that they will not burst into flames.
zap
  • There's an app for that
« Reply #8 on: June 23, 2011, 08:38:01 AM »
Thanks.
PeterDe
http://www.windsun.com/Batteries/Battery_FAQ.htm#Temperature%20Effects%20on%20Batteries
TrackerJack
« Reply #9 on: June 23, 2011, 10:32:17 PM »
Zap's answer is much better than mine.
