Author Topic: Active Pitchcontrol  (Read 348155 times)
mbouwer
Re: Active Pitchcontrol
« Reply #825 on: August 15, 2017, 09:27:46 AM »
I myself also would like to be involved in others who build a small mill.
mbouwer
« Reply #826 on: August 16, 2017, 09:17:14 AM »
The slide yaw bearing of reply #810  I would like to change to a double row ball bearing.
2 outer raceways turned / grinded in the hub.
« Last Edit: August 16, 2017, 02:48:44 PM by mbouwer »
midwoud1
« Reply #827 on: August 17, 2017, 06:21:06 AM »
Few years ago I made a yaw drive  prototype.
Chain sprockets , Worm reduction , Cordless drill-motor.
Never used it in real situation .
Very content with the active pitchcontrol system.
mbouwer
« Reply #828 on: August 18, 2017, 08:33:28 AM »
Really interesting project. Is it still available for home constructors for further build?
The "axle" of the yaw bearing.
mbouwer
« Reply #829 on: August 20, 2017, 05:59:43 AM »
shortening the spacers = iserting more rollers = heavier load possible.
mbouwer
« Reply #830 on: August 20, 2017, 06:21:20 AM »
This construction is derived from reply # 810  Weight: 1747 grams.
I would now like to make a simpler improved version with a slightly larger sprocket.
midwoud1
« Reply #831 on: August 20, 2017, 08:22:29 AM »
I am quite good at working with metal ,but making a slew-bearing I am too young for it.
mbouwer
« Reply #832 on: August 20, 2017, 10:29:15 AM »
Cooperation is the answer.
mbouwer
« Reply #833 on: August 24, 2017, 08:07:02 AM »
Shaping the new light yaw bearing. Filling ring at the holes.
mbouwer
« Reply #834 on: August 25, 2017, 04:11:17 AM »
Found these pinions ( 3 Euro ) Now I need to shape an appropriate sprocket on the yaw bearing.
mbouwer
« Reply #835 on: August 26, 2017, 06:55:03 AM »
Welded teeth at the circumference. Following is the internal assembly.
mbouwer
« Reply #836 on: August 27, 2017, 08:26:45 AM »
Inner ring+roller-raceways.
Thinking another and easier method might be to make the yaw bearing from composite material.
Or 3D printing.
mbouwer
« Reply #837 on: August 29, 2017, 08:24:38 AM »
A base for continuing with the other components.
mbouwer
« Reply #838 on: September 01, 2017, 05:22:13 AM »
First of all, back to the generator.
I would like to make a test rig of an axial generator with a lamination core between the two magnetrings.
mbouwer
« Reply #839 on: September 02, 2017, 08:59:09 AM »
Axle and hub.
« Reply #840 on: September 02, 2017, 09:45:05 PM »
Are you placing the coils on each side...two separate stators ?  Looks great...!
mbouwer
« Reply #841 on: September 03, 2017, 04:33:15 AM »
I thought at 1 stator, with a steel lamination in the coils, between 2 magnet rings.
« Reply #842 on: September 03, 2017, 01:11:47 PM »
Try it both ways..without Steel in the coil holes...then other...might have a bit of cogging..with the steel in the coils...might see a few extra volts with the steel..cogging might take that advantage away..?   Tried it once on a single phase alt..few years back....took a pipe wrench just to spin it around...on my 20-15   Three phase excersize bike alt..with steel in the coils..I can spin that with one finger....it's all in the design...good luck..
mbouwer
« Reply #843 on: September 06, 2017, 06:05:21 AM »
Magnetrings+setting.
mbouwer
« Reply #844 on: September 07, 2017, 08:48:06 AM »
For the generator I could shape the lamination core with the material of a scrap transformer.
Does anyone here have experience with that?
mbouwer
« Reply #845 on: September 08, 2017, 08:55:49 AM »
Lamination core for the axial generator out of transformer sheets.
mbouwer
« Reply #846 on: September 09, 2017, 11:07:29 AM »
New coilwinder. Magnets holding the core and two side plates to wind the coil.
« Reply #847 on: September 09, 2017, 01:24:30 PM »
Nice...
mbouwer
« Reply #848 on: September 10, 2017, 09:47:56 AM »
2 coils of 14 m wire / 10 layers. With inserted lamination core.
I wonder if it makes sense to add laminations in the space between the coils.
« Reply #849 on: September 10, 2017, 12:07:09 PM »
Do a simple test...mount the coil..then run your mags by it...with and without lams..helped out on my pedgen...small amount of cogging..still able to spin with one finger...my coils are mounted to a steel band as well...the coils are fairly thick..so having the metal in the coil hole..helped to magnatize the entire coil...
« Reply #850 on: September 10, 2017, 12:09:48 PM »
Energize the entire coil..might be a better way of saying it..😜
mbouwer
« Reply #851 on: September 11, 2017, 05:04:14 AM »
Better use tapered shaped laminations, coils and magnets?
mbouwer
« Reply #852 on: September 12, 2017, 09:49:49 AM »
Seeing the coils in the mould I think I'd better take another ratio of more and smaller coils and lam.core.
Adriaan Kragten
« Reply #853 on: September 13, 2017, 04:13:33 AM »
Using iron coil cores will certainly increase the strength of the magnetic flux flowing through the coils as the air gap becomes much smaller. Therefore the voltage generated at a certain rotational speed will be much higher. However, iron cores may cause strong fluctuation of the clogging torque depending on the number of armature poles and stator coils. This fluctuation is maximal if the number of armature poles is equal to the number of stator coils. This fluctuation can be minimised if the number of armature poles is two more or two less than the number of stator coils but this requires a special winding (see public reports KD 560, KD 580 or KD 632).
mbouwer
« Reply #854 on: September 14, 2017, 05:18:17 AM »
If I can use transformer sheets the shaping of a lamination core becomes easier.
Hub +rear magnet backing ring.
mbouwer
« Reply #855 on: September 15, 2017, 06:19:24 AM »
The distance between the magnetrings I now can vary up till 34 mm.
Each ring 30 magnets 10 x 5 (thickness 4 mm.)?
mbouwer
« Reply #856 on: September 23, 2017, 04:51:31 AM »
The lamination packages in the mould pressed on a polyester layer.
mbouwer
« Reply #857 on: September 25, 2017, 09:23:59 AM »
Modified coilwinder.
