Byran,
I'll show you guys my idea of how to best power a
cordless power tool...especially a cordless drill.....my thoughts are its a waste of time
to have a cordless drill ....I mean if I'm too far away from a receptacle.....why not
have a NiCad power supply of 18 volts nominal voltage 3.9 amp/hr. (45 NiCad c-size
, 1.2v each) and using a 10 guage stranded wire cord about 6-8 ft. and an adapter
plug in place of the cordless battery ( a few of you have already done this with a
car battery) now this NiCad battery pak will weigh about 5 lbs. with a eye ring if you're
up on a ladder and can hook it on a rung...
First step is to dissassemble 3 of the batteries
to disassemble ....take a utility knife and cut the length of the shrink wrap including
the end fold over .......
Okay ....some pics
next cut fold over on each end as marked, this allows the corner to hinge open and
all 3 stacks slip out, then you remove wires and cut the connecting ribbon in between
the batteries cuts easily with a utility knife....(*careful those little corners are sharp
and can cause at least small cuts that will sting for a week ! *)
Now place in freezer for about an hour....then you canseperate them quite easily
with a table knife, take the middle one and turn it end for end ,glue them back together, some 12 guage stranded wire....twisted and soldered across the terminals
each end......a short piece of wire soldered onto the formered mentioned wire and
inserted into the top of the tab end of a male quick connector and crimped where
the top of the connector is flush with the top of the cell....do the same with the other
end put the 3 back into the shrink wrap cover and after taping back together ,cut
a slit on both sides of the connectors and across the top providing access to the connector. Now connecting 3 of these 6v paks into series gives you a 3.9 amp/hr.
18 volt battery that should last 3 times as long as an 18 volt cordless drill battery.
enjoy !
Norm.
Of course you can just disassemle one 18 volt NiCad , use 12 guage wire , bypass
the thermistor and cutting the package like I've shown is the best way to open and
close it back up when you are done.
