Hi All,...I decided to try using a car alt for some testing....
I cut the wedge pieces off ,...slid a piece of pipe over and attached 12 magnets out of car starters ,to the pipe..
the left is what it looked like originally , the middle is the pipe with mags attached,...and on the right is the stator with six leads coming out ,...and hard to see but a secondary coil added.....
I tested each phase by itself ,at the max rpm of my cordless drill....the best reading was 3 volts dc...Jerry rigged
I tried to add the three individual phases together .....It took a while but finally got it....output at max rpm is now 9.25 vdc....this is how it was connected
.....then I tried my way ,..by hooking the positve of the cap to one of the untied phase leads, instead of the positive out of the bridge, increased the output to 10.25 volts dc ....with all three phases
Now I tried the secondary coil,...
..this is only on one phase the other two aren't hooked in this test....the output was 10.45 volts dc at max rpm of the drill.....
These are just rough #'s , if I have time next weekend will give more accurate ...
The original diameter of the wedged pieces was 12 inches,.. my mag armature was only 11 3/8 inches ...so the gap is big ....more to do.....artv
