Hi Folks,
My brother and I are working on a small wind generator project. After taking apart a few treadmills, we've found a PM motor that looks like it has a RPM/voltage ratio that might do for a generator. Now we're wondering how to match the size of the propeller to the motor for best results. I have Ed Lenz's blade designer program, but it seems more geared for determining the specifics of blade shape rather than bigger questions like what size the blade should be in the first place.
This is largely an experimental project, which will be used to charge some backup batteries for when the power goes out. Since the usual cause of our frequent power outages is wind storms, low wind performance probably won't be a major concern.
The motor is labeled 2.25 HP @ 130 VDC / 2200 watts. I believe it is the same model as this one:
http://www.ebay.co.uk/itm/150664839024 . There is no RPM rating on it, but when we chucked it into our drill press, geared for 620 RPM, the open voltage on the motor was around 19v. At around 1100 RPM we measured 33v.
In order to avoid overheating the motor, I figured we should keep the output current below the rated input current. That is, 2200/130 = 16.92 A. So at a battery charging voltage of 14v we are looking at a maximum theoretical output of around 237 watts. We'd like to drive it directly, for simplicity.
I can put different prop values into the blade designer program, and (as well as the detailed blade measurements) it gives an "estimated prop performance" table with figures for wattage and RPM at different wind speeds. Based on some trial and error with this, it looks like a 2 meter 3-bladed propeller with a TSR of 12 and the default values for angle of attack and lift coefficient (4 and 0.
would be somewhere in the right ballpark.
Does this sound reasonable to you? Is 12 an unreasonably high TSR? Does anyone have rough guidelines or suggestions about what the blade size and tip speed ratio should be for a given generator and wind situation?
Thanks very much for your help,
Adam
