Adam, thanks for the reply.
I guess if someone was wanting to make a simple setup on the cheap they could do alot better than this, in my situation the pipe is only worth $350 the guys are twice that much and then there is the data logging stuff.
This is less than 2% of the cost of my entire install, should I go ahead with it so.. not really a concern in the big picture [well a bigger concern would be incorrect data or location for the same setup producing zilch for power]
I live in a zone 3 w/ 6.7m/s [so says the wind map] Weibull avg [K=1.92].
There are two things I'm trying to nail down, where is the best compromise for tower height and what is my wind speed compared to the wind atlas.
My topology is about like your kitchen table
with little to no trees [farm/grazing land]
Do you have any links to sites which give some form of dimensional ratio for gin pole sizing etc? I've looked [google] and didn't find anything.
I've tweaked my numbers a bit to have a 50ft gin pole [from 3 x 3 0.125 HSS x 48 ft long w/ added plates for each end to pivot and carry the cable connections]
My basic [back of the napkin] numbers for the max loads during the first pull on the haul line using the above gin pole.
4 guys each located on a tower tube joint, each guy is then spaced at 40ft [the top guy would be attached a bit short of the top of the tower, say 5ft short]
Top guy is under 293lb tension load
second from top is under 234lb
Third from top is under 170lb
the bottom guy is under 115lbs
The entire tower weighs ~360lbs and this is assuming there is no load carried by the bottom [ground] connection.
Compression load on the gin pole is 709lbs [radius of gyration would allow a 1463lb load here w/ 2.0 factor of safety {FOS}]
Tension load on my haul down cable would be 1002lbs. If I was to use a two line block/tackle this would be halved [or 501lbs].
The 1/8" steel cable used in my guys is rated for 1700lbs tension. So at worst load the top guy has a FOS of 1700lb/293lb=5.8
Wind loads for a 25m/s wind speed on the upright tower is actually less than the erection loads so I've assumed a 'good' condition there.
Compression loads on/in the tower tubing run it up to ~1500 psi in the material [tubing] which if properly stabilized with the guys on either side should not be an issue.
All I need to do is find a cable set [or rope] that would carry the haul down load and I'm good to go... as far as I can tell? I'm also planning on adding a stabilization rope(s) from the top of the gin pole down to each of the two adjacent guy [ground] anchors to ensure the gin pole stays inline w/ the haul line and the guy connections up the length of the tower, I'm not sure if it's needed but it would seem that there is a possibility of the gin pole wanting to drop to either side.
Am I missing anything [not that I'm expecting anyone to re-run my numbers
JFG
