Author Topic: Wheels on My PedGen  (Read 2186 times)
Wheels on My PedGen
« on: March 13, 2012, 08:01:47 AM »
Finally got some wheels on my PedGen....now I can roll it from room to room
or outside....
 I simply pick up the back end and roll it around like a cart.
  Was thinking about it for a few months, and finally a good idea came to me.
Norm.
Re: Wheels on My PedGen
« Reply #1 on: March 13, 2012, 11:14:38 AM »
Wheels on a stationary bicycle trainer....  ;D
Clever thinking though. That's usually my mode of operation too... pondering a problem for months, then get a flash of insight, and then the executing of the idea is just a formality anymore.
(I recall back in primary school at age 8 or so I was staring out the window. Teacher asked me what I was doing. My short factual answer: 'I'm thinking'. She bought that excuse!)
How's the wear on that bicycle tyre? Asking, because I still intend to build a trainer stand for the rear wheel of my 'bent, with the rear wheel driving a small (250W) motorconversion. I figure it should help me keep me in summer-condition during winter, while at the same time producing a bit of electricity too.
But I understand tyres wear pretty fast when used on stationary trainers (much faster than when riding on the road), so curious about your experience in that respect.
« Reply #2 on: March 13, 2012, 10:08:28 PM »
The tyres wear 'different' on a trainer.
We would put a worn-out decent racing front tyre on the rear rim for the trainer's (roller or fixed trainer) use in winter.
A tyre I would NOT trust to get me 1000 meters to get a pack of smokes would last on a trainer all winter (6000km?) with no issues.
I don't ride them.  I just maintain them, while smoking.
TimS
« Reply #3 on: March 13, 2012, 10:52:12 PM »
I just fell off my trainer, I was laughing so hard  ;)
« Reply #4 on: March 14, 2012, 06:47:34 AM »
Ok so does it slip with cutin torque
 Can you stand on the Crank with the rollers
 I had the lunch out for a long time until I figured out the frequency over lays . I jam it some times and surf others . You can break it up in a Faraday Enclosure also get an old receiver (Stereo entertainment )  set up with an open ended antenna on the mic input or line in if the impedance is right . the mic input is about right  ( just some wire at first and then adapt it to be in the range of 20 HZ to 6K . On the output setup a Transmit antenna  I helps to have a speaker in the circuit but hang a coil on the positive Speaker connection  6 to12 turns on a 5/16 round stock and place a long antenna wire on that . Set the receiver to record so the low frequency that's getting to you is being transmitted out and at slightly different time frame . This will hamper the tracking utility and the AI mainframe interaction  . There are low frequency receivers Freeware on line . The mastering has changed over the years I to remember loosing a lot of time and distortion as I tried to focus . The low frequency both ELF and VLF is everywhere now and  is a problem when I work out or focus ( some freaks will push it until we find all the gear )  . A Van der graff generator is also work able and can unlock  some low frequency mastering . Hang in there I don't Know how this will be received as we come forward with the info just disregard all this it your not ready to face these P)(*&k s . Isolation is the main tactic so keep up with friends and family.
« Last Edit: March 14, 2012, 07:03:39 AM by tecker »
