Just another method of explaining what has already been said:
An electricity generating wind turbine converts kinetic energy in the flow of air through its swept area and ultimately converts some of it into electrical energy.
The kinetic energy in the air is equivalent to one half times the mass of the air times the square of its velocity. Now in the case of a wind turbine, which is generally fixed in location, the amount of air passing through its blades is also a linear function of the wind speed, and as a result the available kinetic energy to a wind turbine is related to the cube of the wind speed, such that if you double the wind speed, the available kinetic energy in the wind goes up by a factor of two cubed, or eight times as much energy is available.
The Cp referred to is the fractional efficiency of the wind turbines ability to convert this kinetic energy into electrical energy. A fellow by the name of Betz figured out that you can not capture more than sixteen twenty sevenths of the available power (because the more you slow the air the less can move past the blades), and actual wind turbines are generally significantly lower than that in efficiency because of friction, electrical resistance and other factors. Additionally this coefficient of efficiency is itself a function of the wind speed for a particular wind turbine.
Now in your case I am guessing that you are asking about an 8kw rated turbine. The rating probably means that the manufacturer is stating that at some given wind speed the turbine will generate 8000 Watts. Since we do not know what that wind speed is we can not even give a rough estimate of the annual power production for this turbine. It would also depend upon the distribution of wind speeds over time. Just because the turbine is rated at 8000 Watts does not mean that you are going to see 8000 Watts for very much time. Additionally there will be times when it is very windy and the turbine may produce more power than your house is consuming, as well as times when it will be calm when the turbine will produce less power than the house would consume. To figure this all out for purposes of determining what percentage of the homes energy consumption you could expect, in addition to knowing the homes actual power consumption over time, you would need to know the turbines power curve, which the curve representing the amount of power generated as a function of the wind speed, as well as the overall wind speed distribution for the location and height at which the wind turbine is to be mounted. This would also enable you to estimate the size of battery bank required to provide power for a certain percentage of the time for an off grid home.
For an off grid situation, where the home is not connected to an electric utility, this usually means charging stationary batteries with the energy generated by the turbine and using the energy from the batteries to supply household power. In the case of a grid connected home, generally with approval of the electric utility, it is more economical to use the power grid as a pseudo-battery, sending any surplus power in excess of what is being consumed at that instant by the home to the grid, and when the power demand of the house exceeds what can be supplied by the turbine, drawing power from the grid to supply the difference. With net metering offered by many electric utilities the home owner then only pays for the net power used from the power grid, or in some cases where the turbines energy generation exceeds the homes consumption, receives compensation for the net power sent to the utility.
Don't know how much this helps you, as I realize it is a bit broad, but the questions have to contain all of the specific relative facts to get specific answers. Rich
